Old 05-31-2010, 03:32 PM   #1
dyno
dyno's Avatar
6.2 glowplug problem
My glowpugs are acting up. They work fine for the inital start, but if the engine dies, they only come back on for a second then it's hard to start. Even after driving it, if I let it sit for a couple hours they wont come on at all. They only come on when the engine is totally cold. These engines are very hard to start even on a warm day if the glow plugs aren't working.
"Built- not bought"
1958 GMC 150 4x4 in progress
1980 K20- Restored
1985 K3500 Flatbed
58 GMC 4x4 build thread:
http://http://67-72chevytrucks.com/vboard/showthread.php?t=557675
dyno is offline   Reply With Quote
Old 05-31-2010, 08:35 PM   #2
Stitch
Location: Where I come from, it's cornbread and chicken...
Re: 6.2 glowplug problem
put a ford starter solenoid in there to replace the glow plug controller and then put a manual switch on it...that's the only solution really to them not coming on when the engine isn't warm enough
Stitch is offline   Reply With Quote
Old 05-31-2010, 11:31 PM   #3
dyno
dyno's Avatar
Cool...can you give me more detail? What kind of Ford starter solenoid? Where the heck's the controller located?
Thanks,
dyno
"Built- not bought"
1980 K20- Restored
1985 K3500 Flatbed
Old 06-01-2010, 12:04 AM   #4
BIGCHEVYMAN
BIGCHEVYMAN's Avatar
the controller is at the back of the intake. there are several wires going to it it is pretty easy to find.
i have my glow plugs set up a littel differently. i have a push button under the dash with wires going to the controller. when i push the botton it energizes the controller. but you really don't need to hold the button for more that 10 seconds at a time. it works great.
BIGCHEVYMAN is offline   Reply With Quote
Old 06-01-2010, 08:02 AM   #5
Stitch
you could do that also...forgot about that...you could wire a switch so it will engage the original controller, that way giving it a jump start when it won't light the glowplugs itself...thanks for clarifying that bigchevyman
Old 06-01-2010, 11:06 AM   #6
BIGCHEVYMAN
anytime fathoe. my glow plug indicator light also works the way i have mine wired.
Old 06-01-2010, 06:38 PM   #7
dyno
dyno's Avatar
Yes, that's how I want to wire mine, where the light on the dash comes on when pushing in on a switch. So do you know what wires to wire the switch to on the controller?
"Built- not bought"
1980 K20- Restored
1985 K3500 Flatbed
