Old 05-31-2010, 05:55 PM   #1
jmedero
jmedero's Avatar
installing CPP c notch and need help
I am installing CPP c notch on my 68 burb. What I need help with is finding the best way to get the air fittings from the bag through the frame, notch and the stupid crossmember that is in the way. The cross member is the one that the shocks mount up to. I have drilled and clearenced the c notch for the fitting to clear and I can do the same on the frame but.... thats a pain and the xmember will still be in the way.
Any ideas? What have you guys done?
Should I remove and move the xmember for the shocks? Let me know what you guys think, and pics of your ideas.
Thanks in advance
Juan
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 05-31-2010, 08:13 PM   #2
8mpg
8mpg's Avatar
Re: installing CPP c notch and need help
just drill through all of it... you drill through the notch, through the frame and through the crossmember. Its like 3/4" of steel.
If you dont want to do that, you can build a top cup with a center bolt that bolts through it all and the air fitting goes inside the cup.
8mpg is offline   Reply With Quote
Old 05-31-2010, 11:09 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
The step bit,... or uni-bits work good.
I think I had to use a 7/8" bit to clean up the hole after I used the uni-bit.
Keith
Convert to disc brakes.
Old 05-31-2010, 11:51 PM   #4
jmedero
jmedero's Avatar
I used the step bit on the notch. I still had to file to get it just right. I was just wondering if any tricks or secrets were out there. I'll just quit whinning and just do it. Lol
