Old 05-31-2010, 07:05 PM   #1
72cheyenne305
transmission shifts late
My transmission shifts late on every gear. it just started this some days its perfect others it revs way to high on every shift. not sure what trans I have someone put an 85 305 firebird motor into my 72 truck and I dont have a clue what it is.
72cheyenne305 is offline   Reply With Quote
Old 05-31-2010, 07:16 PM   #2
cdowns
cdowns's Avatar
Re: transmission shifts late
welcome to the board vheck your tranny fluid level
Old 05-31-2010, 10:27 PM   #3
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Here is a diagram of the pans on most of the auto trannys.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 06-01-2010, 05:06 PM   #4
Secret Squirrel
Secret Squirrel's Avatar
x2 on fluid level. Not a whole lot of fluid in there so a little loss can make a big difference when sloshing around.
If fluid level is good check your vacuum hoses to the trans for cracks? Depending on the type of tranny (if applicable)
________________________
72 Olds Cutlass w/442 option
69 C-10 Short Bed Fleet
1960 Biscayne Wagon/El Camino
1995 YJ 4.0 SOA SYE on 35s
01 Excursion Limited 7.3 PSD
06 Suzuki DRZ 400S
Secret Squirrel is offline   Reply With Quote
Old 06-01-2010, 05:32 PM   #5
Hart_Rod
Hart_Rod's Avatar
Modulator valve?
Hart_Rod is offline   Reply With Quote
Old 06-01-2010, 06:23 PM   #6
raycow
Governor sticking?
Ray
raycow is offline   Reply With Quote
Old 06-11-2010, 07:32 PM   #7
292farmer
292farmer's Avatar
does it have a detent cable? i had a truck with 700-r4 it would shift horrible took me forever to figure out the detent cable was broke. i cant remember if it affected upshifts but it hated downshifts. just my .02
292farmer is offline   Reply With Quote
