Old 05-31-2010, 07:28 PM   #1
blazer2007
new rotor & bearings install ?
I have a 80 2 wheel dr. and had a semi bad rotor so decided to change both and bearings anyway,but I have to go up north[,400 miles] I have a couple days till I leave, so will they seat a little more,and should I re-check the pre-load when the truck is hot or cold.I get paranoid when I do something just before I leave.First 100 miles is, whats that noise.I,ll bring my laptop and someone will tow me home before a cougar gets me, HA
blazer2007 is offline   Reply With Quote
Old 05-31-2010, 08:06 PM   #2
LONGHAIR
Re: new rotor & bearings install ?
There is no reason the have to re-check them. If they were right in the first place, they will be fine.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 06-01-2010, 10:35 AM   #3
blazer2007
well I tighten the nut as I spun the rotor until I starting getting snug then backed it off until loose then tightened by hand and then went to the next cotter pin hole
