Old 05-31-2010, 07:50 PM   #1
JonFrankMc
New Suburban Wheel fitment
This may be a dumb question but has anyone tried these wheels? I have always liked them but I don't know their bolt pattern, I know they are 6-lug, but I don't know the measurements and back spacing.
I think they would look pretty good on the right truck.
Jonathan
JonFrankMc is offline   Reply With Quote
Old 05-31-2010, 08:44 PM   #2
463
463's Avatar
Re: New Suburban Wheel fitment
try this site http://www.roadkillcustoms.com/hot-r...ase.asp:metal:
Trueman
463 is offline   Reply With Quote
Old 05-31-2010, 11:00 PM   #3
71tahoe
71tahoe's Avatar
I have wheels off a 99 z71 and the hub for a 70 truck is about half an inch larger than the 99. Either the wheel or hub will require machining. Using a spacer would be the not so recommended method.
71tahoe is offline   Reply With Quote
Old 06-01-2010, 05:57 AM   #4
Blazer1970
Blazer1970's Avatar
You would need a spacer to get the offset even close to correct. A spacer is the only way to run these late model 6 lug wheels. I would stay away from them for that reason.
Blazer1970 is offline   Reply With Quote
Old 06-01-2010, 11:26 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
yep, not a bolt on. If you were to 'fix' the center hole, then the wheel would be tucked in enough to look way wrong, plus, they'd rub real bad.
I agree with the "wouldn't run spacers" comment
