I'm a poor spectator
Got me a van tilt today!
Went to the junk yard yesterday with a few friends and happened to come across a van tilt from a 77 I believe. Pretty good shape but its for an auto, i'm gonna try to modify it since I have a standard. I'll get some pics later of it but for 40 bucks I think I did alright!
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig ![]() 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! ![]() 1979 Ford F150 4x4 SWB Built Ford Tough!!! ![]() 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
Post Whore
![]() Join Date: Feb 2000
Re: Got me a van tilt today!
Congrats, that will be nice - I'm using an auto van tilt in my 69 - a little grinding and filling and it is now a manual column. I got lucky and didn't need to buy the wiring adapter.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
I cut the pigtails off the van and took them with me just in case I needed them, so hopefully I don't have an issue.
Future TOTM Winner
I'm glad we were able to find you one! Luckily it was pretty easy to pull as well.
Yukon, when you modified yours did you just grind/bondo/repaint the auto collar or did you remove the shift lever linkage that comes out the bottom as well?
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
Active Member
Nice tilt and good buy!
1972 K5 Blazer ALL ORIGINAL paint & engine, A/C, Tilt, 4sp, AM/FM, Tow Hooks, Aux Battery Tray, Tach, Vacuum 2004 FORD FX4 SuperCrew 2005 CTS-V 12 sec family car ![]() 2008 Buick Enclave AWD, Nav, & DVD, Wife LOVES it! |
Post Whore
I just cut the linkage arm off the bottom of the steering column. For the collar, I cut off the offending stuff then cut up a beer can and used JB Weld to affix it on the inside of the collar, then put JB Weld on the outside, let it dry and ground it down - worked very well. Here is a photo album showing what I did.
#7 | |
Future TOTM Winner
did you ever upload the pics?
Post Whore
If you are asking me, the link in my above post still is active and has pics of the modifications I did.
#10 | |
TILT COLUMN GURU
![]() Join Date: Dec 2006
kevs_classics64 64 Impala SS Conv 72 Blazer 2wd 75 Jimmy 2wd 63 Belair wagon 02 Silverado ext cab. DD RIP EL JAY |
