06-01-2010, 11:51 AM | #1 |
Ground strap on a powdercoated frame?
How do I go about getting bare metal on a powdercoated frame without causing damage to the finish? Do I just grind enough off in the spots where the strap will be located? Or am I missing something?
06-01-2010, 12:12 PM | #2 |
Re: Ground strap on a powdercoated frame?
If it is a through bolt fastened by a nut then you will have to find bare metal. I might get flamed for this but if it is a screw that cuts threads into the metal there is no need to expose the frame surface. The threads will make solid contact with the frame and the back of the screw head will make the contact with the strap.
06-01-2010, 06:05 PM | #3 |
I have no bare metal, the entire frame was powdercoated. I was just wondering if I grind a small spot under the strap would that somehow damage the powdercoating?
06-01-2010, 06:18 PM | #4 |
Sisyphus was my mentor!
A better way Gene might be to run a tap through the hole you are going to use to bolt the ground strap the frame. As long as it is bare metal under the bolt head, the current should be able to flow through the bolt & into the frame via the tapped bare threads. If you're concerned with corrosion, a dab of grease or antiseize should keep that at bay.
passthebuck #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
06-01-2010, 06:24 PM | #5 | |
06-01-2010, 06:29 PM | #6 |
You might also consider a "star" or external tooth washer they are generally used just for electrical ground connections as it should bite into the PC or should I say through the PC and into base metal, aside from that I would thread a hole for a bolt to thread into and that should be sufficient for a ground and I would still use the external tooth washer under the ground strap tab.
06-01-2010, 07:26 PM | #7 |
Active Member
Here's what I would do.
I would use one of the small grinding stones similar to the ones below and grind a small area around the hole like you mentioned. Then after the ground strap is bolted in, give it a shot with rustoleum or other rust preventative paint to seal it. |
06-01-2010, 08:29 PM | #8 | |
sharp as a marble
I agree, This is what I have done in the past.
06-02-2010, 12:45 PM | #9 |
Do your grinding on the inside portion of the frame. The connection from the nut/bolt will ground on that side and you can keep the ground wire on the outside. The wire will ground through its connection to the bolt head.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold 1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold) 2003 K2500HD 8.1/Allison1000/NP263 |
06-02-2010, 01:56 PM | #10 |
Champagne Taste on Beer Budget
I would do what the guys are saying above...PLUS once you insert your bolt thru the frame also get a good flat washer and sandwich your ground strap to that then tighten everything down. Then apply a little grease to seal it off.
Good luck.
Coming Soon: Project 1970 Country Truck |
06-02-2010, 02:59 PM | #11 |
I agree with the grinding on the bottom side of the frame. I rhino lined my frame and had to do the same
06-02-2010, 03:45 PM | #12 |
Registered 1971 K5
06-02-2010, 03:54 PM | #13 |
From my previous electrical engineering career: In electronic enclosures, ground straps MUST have a star washer in order to make good electrical contact.
72 Fleet (died) 78 Step (sold) 55 Step named Fred (sold) 00 F150 68 Step (named El Scorcho by PO) Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932 |
06-02-2010, 04:27 PM | #14 |
2WD Jimmy
06-02-2010, 04:36 PM | #15 |
i've never went out of my way to use star washers for at least 45years and have had no grounding issues// actually a star washer i doubt would put a good scratch in powdercoating much less establish a ground
06-03-2010, 08:44 PM | #16 |
Active Member
Might try a piloted bonding brush, kinda pricey but will put a nice 1/2 round spot where you want to ground. type in bonding brush in the search block.
http://www.yardstore.com/
1969 C10 350 3spd 1995 GMC 3500 XC 350 dually When Thomas Edison worked late into the night on the electric light, he had to do it by gas lamp or candle. I'm sure it made the work seem that much more urgent. George Carlin |
06-03-2010, 10:55 PM | #17 |
Man of Mini-Talents
