Old 06-01-2010, 01:04 PM   #1
Lippyp
English Chevy Owner
Lippyp's Avatar
Summit Racing
Are their own brand mini starters any good? I've been trying to source one over here with no luck as it seems everyone is out of stock so I may as well bite the bullet and stick an order in direct with summit for a few bits and pieces I need. If their starters are rubbish what about Jegs?
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 06-01-2010, 01:32 PM   #2
storm9c1
*** That's interesting ***
storm9c1's Avatar
Re: Summit Racing
What engine are you putting it on? Is it a SBC? How many tooth flywheel? Another name for a mini-starter is a "Nippon-Denso" style. And the one that comes stock on a '94 'Vette with the LT1 (VIN: P) 350 is that style, so I just order that starter at Advance for about $115 (with a lifetime warranty) and stick it on. Fits most modern 153-tooth flywheel SBCs that came out before the LS engines. If your engine is older with the 168-tooth flywheel, then you can use one of the "hi-perf" starters listed on the NAPA website for your year/make/model engine. The "hi-perf" version is RAY 2441601 from NAPA.
Never used the Summit or Jegs versions because I've always found them locally for much cheaper and it's the same design. Any Nippon-Denso style starter should last a very long time.
Tom
Chevy by day...
1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E
2011 Chevy Caprice PPV 9C3 6.0L
1995 Chevy Caprice 9C1
1994 Chevy Caprice 9C1 #3
1995 Chevy Caprice Wagon #2
1995 Chevy Impala SS
Mopar by night...
1969 Dodge Charger
1972 Chrysler Newport 2dr Hardtop (27K miles)
Plus others...
storm9c1 is offline   Reply With Quote
Old 06-01-2010, 01:55 PM   #3
jgreene0717
Jason
jgreene0717's Avatar
Re: Summit Racing
I put one on my BBC and it works great. No issues here.
jgreene0717 is offline   Reply With Quote
Old 06-01-2010, 05:37 PM   #4
BADPURPLE70CHEVY
406 Powered
BADPURPLE70CHEVY's Avatar
Re: Summit Racing
I saved a ton and got a mini starter from EMSGLOBALDIRECT off ebay. Check them out. I know 3 people who have bought there and there starters are great.
70 GMC
68 c10
2002 silverado
72 4x4
BADPURPLE70CHEVY is offline   Reply With Quote
Old 06-01-2010, 10:29 PM   #5
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
Re: Summit Racing
If you are cranking a lot of HP or static compression I would steer you away from Jegs brand.
They have a lot of good products but even the guys in retail will tell you that they leave something to be desired.
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 06-01-2010, 10:31 PM   #6
hayhauler71
hayhauler71's Avatar
Re: Summit Racing
I have a summit one on my sb and works great
hayhauler71 is offline   Reply With Quote
Old 06-01-2010, 10:49 PM   #7
1969stepside
1969stepside's Avatar
Re: Summit Racing
i got a jegs one and it eaisly craks my 327 over
Greater love hath no man than to lay down his life for a friend.
Members i Have met
Earl Slick68
1969 Stepside Build thread
http://67-72chevytrucks.com/vboard/s...=1#post4253546
Chevy Trucks the longest lasting most dependable trucks on the road
1969stepside is offline   Reply With Quote
