Old 06-01-2010, 06:19 PM   #1
cris well
4l60e or 4L80e?
I'm about to go look at an engine and trans from a 97 chevy truck 350/auto and i'd like to know what to look for to distinguish the two trannys apart.
I will also write down the casting #'s from the engine and tranny if there are any on the trans.
I know what the vortec motors look like but not the trans.
cris well is offline   Reply With Quote
Old 06-01-2010, 07:31 PM   #2
BigBlocksRule
Re: 4l60e or 4L80e?
4L80E is the easiest of GM's to recognize. It will have a waffle pattern on each side of the bellhousing about the size of your hand. Once you've seen it, you'll never miss it. If you decide to try it by feel, pick it up. If your guts end up in your shorts and it's still on the ground, it's the 4L80E
BigBlocksRule is offline   Reply With Quote
Old 06-01-2010, 11:11 PM   #3
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: 4l60e or 4L80e?
Originally Posted by BigBlocksRule View Post
4L80E is the easiest of GM's to recognize.....If your guts end up in your shorts and it's still on the ground, it's the 4L80E
I had a virtual hernia just visualizing that.....
Member Nr. 2770
Old 06-02-2010, 12:41 AM   #4
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: 4l60e or 4L80e?
4L60E's are more common behind the 350's... However... I had a 3/4 ton Suburban with a 350 small block and a 4L80E in it. That small block worked it's butt off spinning that tranny.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 06-02-2010, 07:32 AM   #5
BigBlocksRule
Re: 4l60e or 4L80e?
They're heavier and take a bit more power to spin, but they're as bulletproof as anything made up to the Allison. I've towed close to 10,000 lbs with one in overdrive all the way with zero ill effects. Can't say that about a 4L60E for sure - they're a decent design for street vehicles but aren't worth much if you're planning to work 'em hard.
Old 06-02-2010, 11:32 AM   #6
cris well
Re: 4l60e or 4L80e?
yea i thought the 60s were behind all the 350s then i read somewhere that it could be either.
i'm gonna ask the guy if it came from a 3/4 ton or a suburban or something.
he wants to trade me the engine/trans/harness/ecm (with 70,xxx miles) for a 700r4 and a set of 15x10 vette rallys with good tires (for a 5 lug truck) that i have.
i'm just considering it at this point.
Old 06-02-2010, 12:36 PM   #7
jb1016
"Oh well, it's a driver."
jb1016's Avatar
Re: 4l60e or 4L80e?
That seems like a good deal to me...
Old 06-02-2010, 01:40 PM   #8
BigBlocksRule
Re: 4l60e or 4L80e?
My '97 1-ton has a 350 and the 4L80E. The truck has 240K miles and nothing has been overhauled yet, great oil pressure and no problems, KNOCK ON WOOD!!!
Old 06-02-2010, 01:47 PM   #9
cris well
Re: 4l60e or 4L80e?
that's what i like to hear.
i have a 93 sierra sle sportside with about 285,000 miles with the 4L60e rebuilt about 2 years ago but not the motor.
still runs like a new one. it has been well taken care of.
Old 06-02-2010, 11:40 PM   #10
Tom
driving is in my blood
Tom's Avatar
Re: 4l60e or 4L80e?
Plenty of vortec 350/4L80e combos out there, just none in 1/2tons.
