Old 06-01-2010, 06:27 PM   #1
crisco
87 454 TBI only starts with starting fluid
All of the sudden my crew cab died on the way home a few months back. (I don't drive it much)
It starts on starting fluid, and will stay running. It even restarts if it doesn't sit for long. It's like the system is bleeding down fuel pressure and not getting a signal to turn the pump on until it's running.
SO, in a nutshell, the fuel pump works, there is spark, and it runs. Just wont start on its own.
Has anyone on here ran into this problem and diagnosed it?
crisco is offline   Reply With Quote
Old 06-01-2010, 08:48 PM   #2
ak_nut
Re: 87 454 TBI only starts with starting fluid
check your filter and I would say your pump is going out..
ak_nut is offline   Reply With Quote
Old 06-01-2010, 09:30 PM   #3
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
well it sounds like a fuel problem. if it was my truck I wouldnt want to just throw a part on it... I would see about hooking up a fuel pressure gauge to it and see what it does (or doesnt) do. Then go from there. you can probally put a T fitting in near the fuel filter to make things easier.
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
