Old 02-14-2003, 09:20 AM   #1
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Blazer seats
What would be an ideal fabric to use for blazer seats??? I live in oregon and get rained on from time to time and dont want the carpet or seats to mold like it did when i bought the blazer.... Thank s luke
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 02-14-2003, 10:21 AM   #2
smokekiki
Mike
smokekiki's Avatar
Rubber floor mat and Wet Okole or saddleman waterproof seat covers.I have the top of most of the time.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 02-14-2003, 01:31 PM   #3
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
They have neoprene seat covers at Costco right now. They are less than $20. Probably don't fit as well or last as long as the Wet Okole, but 1/10th the price.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 02-15-2003, 12:22 AM   #4
FRENCHBLUE72
PROJECT 7DEUCE
Does wet okle have covers for a bench i have only seen buckets and where can i get saddleman covers ,i have never even heard of them...
MEMBER #6377
Project "7DEUCE"
Old 02-15-2003, 11:32 AM   #5
smokekiki
Mike
smokekiki's Avatar
You can get saddleman thru summit.I think wet Okole sells for bench,they have them for the rear seats.They have a web site at www.wetokole.com and will send samples of material
Old 02-15-2003, 11:48 AM   #6
FRENCHBLUE72
PROJECT 7DEUCE
Great i found the saddlemans in summit ....So what would you do for carpet ....I was gonna run some dynamat then some type of marine grade foam with ????? for carpet...
MEMBER #6377
Project "7DEUCE"
Old 02-15-2003, 12:32 PM   #7
crazy4chevs
crazy4chevs's Avatar
Spray in bed liner! water cant get under it like it can with a mat.
70 chev c10 swb fleet
72 grill, sb 400, 2/4 drop.
68 chev c10 swb fleet
Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C
Classic GM Truck Club of Washington
crazy4chevs is offline   Reply With Quote
Old 02-15-2003, 01:26 PM   #8
smokekiki
Mike
smokekiki's Avatar
Thats what i am planning on.The rubber mat i have is cut to go around the seats.I can pull it out and put it back in after the floor dries.
Old 02-18-2003, 01:19 PM   #9
bouncytruck
SKINNY TIRES RULE!
I'm planning on doing a Line-X on the whole inside of my truck. If you do carpet, make sure that you pull it out often and let the floor and the carpet dry thoroughly.
bouncytruck 1972 K5
