Old 06-01-2010, 07:51 PM   #1
sixbangr
sixbangr's Avatar
250 timing marks
It should be at around 11 o'lclock, it is at 9. I assume the only way for it to be this far off is for the gears to be in wrong. I tried setting it, it won't run if you lower it to the marks.
1961 Apache short step.
sixbangr is offline   Reply With Quote
Old 06-02-2010, 02:49 PM   #2
raycow
Re: 250 timing marks
If you can't set the ignition timing on the mark, the outer ring of the balancer could have slipped. It is held in place by a rubber to metal bond and this bond can fail over time.
Pull the plug on #1, then put a pencil in the hole and turn the crank by hand to check TDC.
Ray
raycow is offline   Reply With Quote
Old 06-02-2010, 06:20 PM   #3
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Did you disconnect the vac advance? if not it will really mess with timing .
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 06-02-2010, 08:24 PM   #4
mr48chev
mr48chev's Avatar
This a photo that 68Gmcee posted in another thread a couple of weeks ago but is a good example.
here you can see the timing mark on the damper down at about 3 oclock.
Do as Ray said and pull #1 sparkplug (the front one) and with your finger over the hole have someone bump the engine over so that it comes up on compression. when the timing mark is close to the mark on the tab you can then use a pencil or piece of welding rod (LONG enough so that it can't be lost down the cylinder) to check and see when he piston is at top dead center by turning the crank with a ratchet or flex bar and socket. Once you know it is on top dead center, check to see if the mark on the damper is or isn't lined up with the 0 on the timing tab. If it is off at that time you can put a new mark on the damper at 0 but the rubber ring between the hub and outer ring may be suspect and the damper probably should be replaced.
Once you know that your timing marks are right hook your timing light to the #1 (again front) spark plug wire and check the timing with the vacuum advance hose disconnected and plugged.
