Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 06-01-2010, 07:58 PM   #1
Daddy64
91 S10 no spark at coil
Hello, I'm new to the s10 area. I just got a 91 with a 2.8 that will not start. This is a future V8 project but I really want to get it running now just to make it easier to move around between projects. I replaced plugs and coil but still no fire at coil. Question is what could be next? I don't want to throw alot of money at it right now. Thanks HB
Daddy64 is offline   Reply With Quote
Old 06-01-2010, 09:48 PM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: 91 S10 no spark at coil
Remove the ignition module. Have it tested. Does everything else electrical work?
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 06-02-2010, 09:12 AM   #3
Daddy64
Thanks for the reply. Yes lights,horn,radio,etc. all work. I'll test that module. Where can I take it? Thanks again.
Old 06-02-2010, 03:21 PM   #4
Tink
Tink's Avatar
It is located under the distributor cap. They commonly go bad on S10s... when they do, you usually will not have spark nor will you have fuel spraying from the injectors upon cranking.
Most parts stores will check them as far as I kniow.
69 Chevy C10
88 Sierra
02 2500 Suburban
And too many S10s to list!
Tink is offline   Reply With Quote
Old 06-04-2010, 10:27 PM   #5
Daddy64
Bingo, it was the module. Thanks again.
Old 04-18-2012, 05:57 PM   #6
Daddy64
Just a quick update. I was looking at these older post and saw this one. Truck just turned 300K and still running. This forum always gives great advise.
Old 04-22-2012, 10:58 AM   #7
Warrens69GMC
Warrens69GMC's Avatar
I just bought a S15 and the guy advertised it as having no spark, but having a new coil. I brought a new module with me and drove it home.....
Old 04-22-2012, 08:22 PM   #8
gchemist
gchemist's Avatar
I wish I could have seen the previous owners face when it fired up!!
Old 04-23-2012, 02:17 AM   #9
Warrens69GMC
I will post a new thread in a few days on the truck.
