06-01-2010, 09:00 PM | #1 |
67 C10 Dashboard removal mystery???
Tis a mystery. We've got what we think are all bolts loose, the front metal wiggles loosely, the instrument cluster removed, and it seems to be still attached somewhere back where the windshield comes down. If anyone knows the secret to removing the dash, it would be greatly appreciated!
06-01-2010, 09:05 PM | #2 |
Roadtrip!
Re: 67 C10 Dashboard removal mystery???
Looks for some spot welds... They are there. Do you have the glass out? I think you will have to pull that also.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
06-01-2010, 09:09 PM | #3 |
Project '67 454
yep, the glass must come out to get to the spot welds
67 C-10 SWB Fleetside 454 (current project) 99 Crewcab SWB Dually 454 75 Datsun 280ZZ430 94 Formula 232LS 454 |
06-01-2010, 09:40 PM | #4 |
The Older Generation
06-01-2010, 10:50 PM | #5 |
and I had hope one day of puttin gin that factory air conditioning with the dash but if i want to paint it right i have to remove the dash
06-01-2010, 11:03 PM | #6 |
yep, it's spot welded in. When I took mine out I used a plasma cutter and cut it under the dash pad and just removed the face of it. Replaced the face, welded it in and put the dash pad back on. You can't even tell that it's not the original dash
06-01-2010, 11:10 PM | #7 |
Ouch! hmmm...maybe we don't need to take out the entire dash! (I really don't want to remove the glass and grind welds (and reweld) them!)
Can the pad be replaced? LMC or others carry replacement dashboard pads? Thanks for the help! Mark |
06-01-2010, 11:15 PM | #8 |
SWB 4x4 Collector
Yes, you can buy new dash pads. There are the screws on the outside of the pad, and then there are bolts going the through the dash under the pad. Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
06-01-2010, 11:39 PM | #9 |
So the pad has a base as part of it...I mean it isn't just a wrap around, glued on pad? (I found most of the bolts up underneath...a quick-nut fastener on them, but we are having trouble getting the two on each end out...quit for the night!)
Thanks again.
Mark 57 Austin Healey 3000 (sold many moons ago, unfortunately) 67 C10 (in progress, son's) w/ 1993 350 SBC, '96 Vortec heads (custom polished ports), EPS Performer intake, Holley carb, cam, MSD ignition 93 C4 Corvette (mostly done, son's) |
06-02-2010, 12:05 AM | #10 |
SWB 4x4 Collector
Mark, you need to pull the gauge panel out, and also the glovebox cardboard to get to the outer bolts, if you hadn't already. Trevor
06-02-2010, 01:23 AM | #11 |
why are the no rep points on this forum does anyone know sorry to go off topicjust wanted to rep super
06-02-2010, 08:00 AM | #12 | |
Admins removed them because the rep system was being abused so much.... LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 06-02-2010 at 08:00 AM. |
06-02-2010, 10:29 AM | #13 | |
Thanks for the great answers! Mark
