HEI cap and rotor
Are these standard pieces, or did they change a lot over the years? The PO on my truck converted it to HEI, and I want to get a new cap and rotor, but am not sure what to ask for at the parts store.
Also, if you pull a plug wire at the dist with the truck running and the visible spark from the cap is intermittent only, does that mean I have an issue, or does it not necessarily produce a visible spark with every rotation with the wire off? As stated in several other threads, I'm trying to track down a power loss / backfiring issue and am going through the whole ignition. Plugs were done yesterday...I'll do wires today, and a cap and rotor if there's no difference there. Timing is about 10 degrees at 850rpm. Should that be backed off a bit...say to 6 degrees? |
Junior Member
Re: HEI cap and rotor
If it is the type Hei with the coil in the cap it is pretty much standard for quite a few years.
I usually ask for cap and rotor kit for a 77, other years would fit ok also but I can not remember the year range. I usually go on either the O'Rielly or Auto Zone web-sites and check things out. Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
Junior Member
My son usually sets the timing at 12 at idle with the vacuum advance hose disconnected and plugged to start.
Danny
OK...I didn't disco the vacuum. I'll do that and check it again.
thanks. |
