Used to have a truck
woo hoo. Hit the "H"
I was driving home from the airport late last night and the highway was pretty empty. Pu the foot into the throttle at one point just to see what it would do with the new cam. Before I could chicken out it wrapped that speedo needle all the way around to the "H" on the speedometer. My estimate is thats in the 120 mph range. Thats with 4600 lbs and the tailgate up. Like a hot knife through butter.
No truck :-( |
I finally got an avatar
I got mine to the "P" once, before I did a lot of the motor work. It's amazing how much power it takes to get one of these trucks to go that fast. Not only are they heavy(mine's only 3820, I love shortbeds), but they have the aerodynamics of a parachute
-72 C-10 short step (straight line only) 12.922/102.28 -69 C-20 on Propane (DD) -69 C-10 -56 Mack B-753LS (tow rig) -94 Chev K2500 Short Ex-Cab -89 Isuzu Trooper...Kinda -03 Kawasaki KFX-400 -05 Suzuki DRZ-400S |
Fabricate till you "puke"
when that speedo comes around ,& back up to 15-20 mph they have a really lite feel on the road(BB olds on a set of 3.40 coggs)
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
67-72 Addict!
Cool Mike!, I've only had mine up to 100 one time with my present setup. My new cam finally goes in tomorrow!. Can hardly wait.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
Pronounced "Pew-al-up"
Too funny!!! So how far will a Speedo wrap around??
Anyone tested one further than Mike? I am going to try after a few mods!! There is some great spots to really kick it in around here. Hey Mike were you on Hwy 16 or out on the Interstate?? ![]()
Classic GM Trucks of Washington Club Member 1970 FS chevy,350/350, Edelbrock cam and intake. Holley 650 carb,HEI,AT,Tangier Orange, 18's, Power Locks, Truck Photos |
It'll go faster than that. Thats just where I chickened out :-) . I was on Hwy 16 betweenn Gig harbor and Port Orchard and was running at 4700 rpm at the time I stopped pushing it. The last time I tried this it was with a smaller runner intake and a smaller cam but the real problem was that the HEI was cutting out pretty bad at about 95 mph. I since switched to an MSD module in my HEI and all the hi rpm missfiring went away immediately. What amazed me was how fast it got to 120 mph . The engine wasnt really even straining to get there. I doubt it took even a half a mile to get from 70 to 120 which certainly wasnt the case before the cam change to he solid lifter XS274s I am running now. I will say that I lost about 3 mpg on the highway though. In the next month I hope to be getting a new set of Pro Action heads to replace my WP's which should kick me up to around 460-480 HP. I'm also limited by the carburetor and a switch to a 750 holley is imminent. I'll see how it does then but I'm fairly sure I wont be running it that fast again any time soon. Its a stable truck all right but its still like riding in a brick through a hurricane when your'e going that fast in one of these.
No truck :-( |
Had mine past the H a few times, its a bit scary, but what a thrill. Runnin a 402 with a mild cam and stock points distributor. Just got a new cam and HEI. It will be a while before I get it back together and runnin again, but I can't wait!
Livin' it up.
![]() Join Date: Nov 2001
i've taken mine to the zero mark a couple times, but i tend to do this on the 405 or 101 freeways... not so smart!
-Greg; Sold the 69 C20. It's off to a better home with more love! Now onto the 86 CUCV M1009; K5 blazer with 6.2L diesel, corp 10 bolt axles, Detroit locker in the rear, trutrac front, 3.73 gears, 35" tires. ![]() |
Years ago I got the Jimmy up to ~108 with 35" MT Baja beltes (S speed rated to 112 at least...) 4800 rpm. And that was it. Aerodynamics and max torque met head on.
huh ???
You want a fun rush? I raced a tuner one night. He didn't know what to think when the diesel started to wind up.
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
its all about the +6 inches
I had the GMC right inbetween the M and the P once on a Texas back road...I kinda chickened out going any faster, but she was still tugging. Muine is just shy of 4000 pounds. (kinda porkey for a short bed huh?)
I always thought of the aerodynamics more akin to a barn door. ![]() |
MikeP,
I PM'd you!
#13 |
Bremerton
MikeP
I have been to the raceway a couple of times, have you ever or are you ever going to run out there? cleatus
"What we are dealin' with here is a complete lack of respect for the law...." Beuford T. Justice |
#14 |
![]() Join Date: Nov 2000
Believe it or not, I once got my truck up to the 20-30. I chickened out at that point, but right before I let off, I hit the pedal to the floor a couple more times and it had plenty more juice. Man that 327 was yelling! And these trucks do have a very light scary feel at that speed. It was on an open highway in NM where you can see for miles. Funny thing,--I caught up to and passed a 67-72, and scared the heck out of two guys. It's also very scary to see how fast you catch up to cars doing regular speeds, it seems like they're standing still!
#15 |
being still in high school with a bunch of rich kids whos daddies buy them ford lightnings and stuff like that we got out to one favorite racing spot one night and in my 71 c/20 i smoked the pants off of a 98 chevy with all kinds of mods and it was a shortbed but by the time i started to let off my speedo was back around at about 15mph, very exihlerating
#16 |
That's what adrenaline is made from!
#17 |
![]() Join Date: Oct 2002
I had my 94 up to 90 once. Whats so amazing about that you ask? Maybe it had to do with the fact that I had a car trailer behind me, with a complete 73 Nova on it. That was cool to know that it would pull to that speed. The real funny part was when I stopped to get gas and the fox box mustang that I passed a few miles back stop at the same place to get gas. The driver was like "Damn, your crazy! You passed me like I was standing still." So maybe I am.............
So does anyone want to buy my truck? Its been babied it whole life. Never been over 75MPH. ![]()
1969 Chevy Project SWB Fleet, 20s, 5.3, t56, in the weeds. 1970 Chevy Truck cab on a 1979 Jimmy frame-8.1 liter 496 bbc/sm465/np203-jeds doubler-np205/d60/14bff Welded/42 tsls on recentered H1s 1998 Chevy Crew Cab K3500 SAS'd with hpd60, links and swayaway coilovers. 8.1l vortec DD/towrig "I like long walks, especially when they are taken by people who annoy me. " |
#18 |
registered IWATA user
when i took apart the guage cluster from my 69 the speedo wouldn't go back around past 0. i'm not calling bul**** but thats what mine was like. i'vehad m nele pointing str8 down before, the week i bought it, i was a stupid kid. now it doesnt go over 55
-'63 Ford Fairlane 500 coupe, v8, auto, faded and rusty. awaiting built roller 302 and some flat black -'99 Honda Prelude. vtech/5spd. no pipe, no intake, bone stock. awaiting new top end. -01 GMC Yukon SLT 5.3 dented and scratched with a noisy tranny. Take off that Von Dutch hat before i stab you with a 000 Mack. |
#19 |
You people scare me. Not really, I got my 71 around to the 5 mph mark one night (late on a long straight stretch) well not that long, I live in WV and there aren't too many straight roads. Anyway, I had just built the truck and had a 455 big block Buick in it and the oil pump went out at that speed. I drove it on home clunking way down deep in the motor. Pulled it out, sold some parts off it on ebay and installed a small block 350. Havn't drove that fast since.
"The World's a Mess"! 71 C-10 72 Suburban 2WD Oceana, West Virginia |
#20 |
When I was in HS, I went past the 100 mark, but it was late at night, and I got to thinking what if a deer jumps out in front of me. She was still pulling pretty good.
On the other hand, driving my car at 90 is like driving my wifes car at 60. :P |
#21 |
Cool....chev stories! Mike p, a 3/4 ton truck running at 120 + is pretty impressive!........yes, it will go faster, just depends on how d@mn crazy you are
#22 |
I rolled my truck down the driveway last week I bet I got it to
5 MPH Cool Huh ?
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
#23 |
Cool Mario!....it was rollin
#24 |
SLOW BUT SURE,BUT CLOSER
Gee Mike, I thought you had a overheatin' problem
69 C-10, OWNED 35YRS... 350 over 30, 350 Turbo, 3:73 Posi P/S, P/B Black with red and black int. ''LOVE THESE OLD ''TRUCKS....... ![]() ![]() ![]() |
#25 |
damn u brave ****s. i get so much wind noise and shakes by 100 that i always let off..... come to think of it im pretty sure it was me shaking.... coulda been me making the wind noise too.
there's a fine line between bravery and stupidity though... watch out for it. |
