Old 06-02-2010, 04:44 PM   #1
1971ls1longbed
1971ls1longbed's Avatar
hotrods to hell
has anyone used their products or know anyone who has used them
1971 Custom 10 LWB. 461 BBC and built 700r4 to be transplanted
1997 C3500 DRW Ext cab. 454, 4L80E daily driver
1971ls1longbed is offline   Reply With Quote
Old 06-02-2010, 06:51 PM   #2
SCOTI
SCOTI's Avatar
Re: hotrods to hell
They offer decent 'kits' but the truck kit is not worth the cost since these trucks already came w/truck arms. The adjustable height spring seats aren't necessary for these trucks. The adjustable Panhard bar is desired but last I checked, they didn't sell partial kits; all or nothing.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-02-2010, 08:31 PM   #3
1971ls1longbed
Re: hotrods to hell
my truck arms are in bad shape so i was going to replace the whole rear suspension any way and it need to stand up to 700rwhp
Old 06-02-2010, 10:39 PM   #4
LEEVON
LEEVON's Avatar
Re: hotrods to hell
Pretty sure this guy runs stock rear suspension:
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 06-02-2010, 10:53 PM   #5
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: hotrods to hell
^^that thing is SWEET
John
1999 Toyota Tacoma 4x4
Old 06-03-2010, 08:38 PM   #6
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
Re: hotrods to hell
negitive.
http://www.ls1tech.com/forums/multim...arm-truck.html
sleeper truck is what that is
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 06-03-2010, 08:46 PM   #7
SCOTI
SCOTI's Avatar
Re: hotrods to hell
Originally Posted by 87chevy.com View Post
negitive.
Where does it list the suspension info?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-03-2010, 10:01 PM   #8
1971ls1longbed
Re: hotrods to hell
so who makes a really good set of arms and a good panhard rod setup
Old 06-03-2010, 10:36 PM   #9
SCOTI
SCOTI's Avatar
Re: hotrods to hell
http://porterbuiltstreetrods.com/site/
He's a board supporting vendor.
http://www.classicperform.com/
Fewer options & also a board supporting vendor. Support the site!
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-04-2010, 04:37 PM   #10
JEM
Ironmonger
Re: hotrods to hell
What is it you're trying to do:
Do you want to go low, or go fast?
If you want to go fast, are you talking about straight-line fast or sticking-to-the-road fast?
How much do you care about aesthetics? (do you want tubular or do you mind if it looks like stock)
JEM is offline   Reply With Quote
Old 06-04-2010, 05:20 PM   #11
1971ls1longbed
Re: hotrods to hell
actually i want low, fast, curves and straight and if they r really strong i think stock looking would be really cool
Old 06-04-2010, 06:37 PM   #12
DKN
Active Member
Re: hotrods to hell
The CPP tubular trailng arms and crossmember are STRONG. The arms are made with 2" .25wall DOM tube (CNC bent) and plated with 3/16" laser cut steel. We weld more tube internally thru the U-bolt and spring mounts. The crossmember is laser cut 1/4" steel and formed on our CNC press brake.
We have a customer with a turbo diesel that makes over 1100hp and 1600lb/ft torque measured at the wheel. He drag races and pulls a fith wheel trailer. He went thru several modified OE arms before we hooked him up with ours
Danny Nix
CPP
DKN is offline   Reply With Quote
Old 06-05-2010, 08:19 AM   #13
Wild83C10
Wild83C10's Avatar
Re: hotrods to hell
There are a few guys on here running stock arms in the 9-10 sec 1/4 mile range (check out the racing and HP section). I just switched to a set of stock arms on my '83 (welded the seam). I am looking at 700 hp/700 lb-ft of torque (it's the torque that will break stuff anyway). If you have or find a good set of arms then I think you will be fine. Of course if you have the money to upgrade might as well. I do plan on upgrading to the CPP arms in the future, just spent too much already on my current setup.
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 06-05-2010, 07:27 PM   #14
WellBilt Kustoms
Re: hotrods to hell
Here is a picture of some stock c20 arms I modified for the truck were building in the shop right now.
Just some info on them. They are stock c20 arms, we took them to get sand blasted, then I fully TIG welded the top and bottom seams, stich welded the top and bottom plates, and boxed in both sides with dimpled holes. Again all tig welded, then smoothed out. And were putting energy suspension polyeurothane bushings in them.
Before:
Blasted arms ready for welding:
Starting to weld them up:
Finished:
Powder coated:
WellBilt Kustoms is offline   Reply With Quote
Old 06-05-2010, 07:39 PM   #15
noonzor
Re: hotrods to hell
those look siiick. very nice welds!
69 c10 Shortbox Build
http://67-72chevytrucks.com/vboard/s...d.php?t=360622
noonzor is offline   Reply With Quote
Old 06-05-2010, 08:59 PM   #16
1971ls1longbed
Re: hotrods to hell
HOLY CRAP those are awesome how much for a pair
Old 06-05-2010, 09:52 PM   #17
WellBilt Kustoms
Re: hotrods to hell
Hey thanks guys! I appreciate that! I have about 18 hours in those two arms. but the customer was VERY happy!
1971ls, sent you a pm back
