06-02-2010, 07:08 PM | #1 |
AKA "Hurricane Hank"
stripped bolt hole
Hey all. haven't been on this site in almost a year. Glad to see it still up! I just rebuilt my th350 & got it installed only to find the "s" pin inside on the linkage was backwards. I took the pan back off & got that turned around, but when putting the pan back on, I stripped one of the holes at the back of the tranny by the modulator. I struggled for an hour or so trying to get a smaller bolt through the hole & put a nut on it, but couldnt.
Am I better off just rethreading the hole & putting in a bigger bolt? I don't own a tap & die set, but I'm sure I have a friend or two with one.
"looking back, knowing that you gave it your all.... win or lose, you finish a Champion" Dale Earnhardt "They say hard work never killed anyone, But why take a chance? 63 GMC C10 Custom LWB 355/350 AT 00 Chevy Silverado 1500 base V6/AT 07 Chevy Monte Carlo SS 5.3 V8 |
06-02-2010, 07:23 PM | #2 |
Re: stripped bolt hole
you might try a "heli" coil. There available at alot of automotive stores.
Shawn 1966 short fleet 230 I-6 three in the tree (daily driver) 1966 short fleet big block th400 (building slowly) 1972 c10 3 door suburban 350 th350 (building faster than slowly) 2004 F250 power stroke (not dependable enough to be a daily driver) 2005 Kenworth T-800 Heavy Haul tractor (that's my true daily driver) |
06-03-2010, 02:19 AM | #3 |
Lowe's sells matched sets of drill & taps, so you don't need to purchase an entire set, however, if you plan to do much wrenching on your rig, a good, SAE tap/die set is a wise investment.
06-03-2010, 10:03 AM | #4 |
X2 on the heli-coil. This type of repair will allow you to use the same bolt, provided the threads aren't damaged.
Chris 1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas 7.02 @ 95.8, 1.45 60' 1965 Chevy C10 LWB, 355 sbc, TH350, daily driver |
