06-02-2010, 09:14 PM | #1 |
NEW Porterbuilt Bolt-in C-notch for mild drop
I thought I would post up some pics of our new two piece bolt-in c-notch. I have been trying to find the time to finalize this thing for quite a while now… finally buttoned it up a couple weeks ago! This notch will be part of a complete mild drop system we will be releasing shortly, or we will be selling it separately for $249. This isn’t just an ordinary bolt-in c-notch… I put lots of thought into its design to ensure strength, and ease of installation. The fit on these notches is the best you can find in a production notch. We use factory frame-rail sections as a fixture to build them. Its two-piece design make installation a breeze. It locates using the two factory shock cross-member rivet holes on the top of the frame-rails, and then several holes are drilled. The first notch section can be used as a template and a support to cut the notch out of the frame-rails…. no more cutting, test fitting, cutting, test fitting, cutting… you get the picture! Once the frame section is removed, the lower notch will bolt in to the side and bottom of the rails. The lower section uses factory rivet locations on the bottom side of the frame, and also incorporates an air bag/spring plate (making it easier to drill the frame for mounting the air spring). The factory spring stiffeners remain in the chassis, keeping this baby as strong as possible. I will post more pics of the notch once I complete the mild drop kit I was referring to. There’s also more pics on my site for those who want to see more.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
06-02-2010, 09:36 PM | #2 |
What was I thinking?
Re: NEW Porterbuilt Bolt-in C-notch for mild drop
Sweet!!!
06-02-2010, 10:01 PM | #3 |
very nice nate!
06-02-2010, 10:26 PM | #4 |
This is what I've been waiting for. Lets hear more about "This notch will be part of a complete mild drop system we will be releasing shortly"
Nate 1967 short fleet Project Blue Goose 'If it don't bounce back... heeheehee you go hungry!" Blues Brothers |
06-02-2010, 10:55 PM | #5 |
Grandpa in the rustmobile...
more about the mild drop kit..
nice man you put out some very nice products
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
06-03-2010, 01:17 AM | #6 |
nice product, looks very simply laid out for install! i know my cpp notch didnt line up quite right when i originially cut, now chose to weld up and fill in for better strength.
as always a nice product nate! |
06-03-2010, 10:29 AM | #7 |
Happy to be here
Another well thought out product from the fine folks at Porterbuilt. Thanks Nate.
06-03-2010, 10:44 AM | #8 |
Never Done?
Wow, this is a beautiful piece. I don't know when, but I will be buying one!
06-03-2010, 04:23 PM | #9 |
GM Addicted
what is this mild drop more info nate..
..Mac’s Garage.. 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
06-03-2010, 05:31 PM | #10 |
powdercoater
Very Nice,I was going to ask you about a notch kit,now i don't,i just have to
add it to my list of things to buy from you.
SCOTT |
02-27-2013, 02:00 PM | #11 |
Looks like some good Quality Parts.
Posted via Mobile Device |
07-25-2013, 10:12 AM | #12 |
Any word on how this notch affects towing/hauling capacities? I want to still be able to use my truck after this kit is installed. Just trying to do my homework. Thanks!
James |
07-25-2013, 12:11 PM | #13 | |
This notch necessitates the removal of right at 1/2 the original frame width. This significantly decreases the strength of the chassis. Our bolt-in notch is a two-piece design that is stronger than the standard c-notches on the market... but not something I would recommend towing with. It is perfectly suitable for every day driving and light use as a truck is intended to see, but if you are planning to do any towing I would recommend NOT notching the frame. Let us know if you have any further questions. Nate
07-25-2013, 08:43 PM | #14 |
Thanks for the quick answer. I was reading some stuff on here, but the thread was started by a guy whose account was suspended, so I didn't know how much truth was behind the theory. I appreciate the honesty and may do business with you on other pieces later.
James Posted via Mobile Device |
07-28-2013, 11:26 PM | #15 |
Nice product as always Nate!
07-29-2013, 08:54 PM | #16 |
Placed my order with Dave today, super easy thanks.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
07-08-2014, 03:08 PM | #17 |
Does this notch allow you to keep the factory shock crossmember in place, or do you have to run the one you provide? I have recently dropped my Blazer and I don't want to have to change shock setups already, but I really like the 2-piece design of this notch over the others available. If (when?) I decide to go lower, I am thinking that I would want to use your mild step notch, would there be any problems changing to that later on down the road?
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
01-15-2016, 07:19 PM | #18 |
Is this the same notch that POL sells? If so they're giving you no credit...
https://www.performanceonline.com/19...-Bolt-in-Type/
1968 LWB C20 / AC / Wood Bed |
01-15-2016, 11:02 PM | #19 | |
01-16-2016, 01:24 PM | #20 |
Some POL stuff is from CPP.
01-16-2016, 03:17 PM | #21 |
Wish someone did this for a 1954 Model
01-18-2016, 11:15 AM | #22 | |
Good ideas are always copied.
04-04-2017, 09:57 AM | #23 |
Is this still available? I was just browsing the Porterbuilt website and didn't see one for a 67-72.
04-04-2017, 03:57 PM | #24 |
Diggin The SquareLife
call them or email them
04-04-2017, 04:25 PM | #25 |
Edited....
