06-02-2010, 09:19 PM | #1 |
NEW Porterbuilt Bolt-in C-notch
I thought I would post up some pics of our new two piece bolt-in c-notch. I have been trying to find the time to finalize this thing for quite a while now… finally buttoned it up a couple weeks ago! This notch will be part of a complete mild drop system we will be releasing shortly, or we will be selling it separately for $249. This isn’t just an ordinary bolt-in c-notch… I put lots of thought into its design to ensure strength, and ease of installation. The fit on these notches is the best you can find in a production notch. We use factory frame-rail sections as a fixture to build them. Its two-piece design make installation a breeze. It locates using the two factory shock cross-member rivet holes on the top of the frame-rails, and then several holes are drilled. The first notch section can be used as a template and a support to cut the notch out of the frame-rails…. no more cutting, test fitting, cutting, test fitting, cutting… you get the picture! Once the frame section is removed, the lower notch will bolt in to the side and bottom of the rails. The lower section uses factory rivet locations on the bottom side of the frame, and also incorporates an air bag/spring plate (making it easier to drill the frame for mounting the air spring). The factory spring stiffeners remain in the chassis, keeping this baby as strong as possible. I will post more pics of the notch once I complete the mild drop kit I was referring to. There’s also more pics on my site for those who want to see more.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
06-02-2010, 09:36 PM | #2 |
Re: NEW Porterbuilt Bolt-in C-notch
If I can ask .... I see you have the items, or parts, fire (lazer or plasma) cut .... why? Do you or have you used water before. I think it makes a better cut, requires less clean up & doesn't use ANY heat to cut the pieces. Just asking.
Again - nice piece ... like your other stuff. Ratty 46 |
06-02-2010, 10:18 PM | #3 | |
06-02-2010, 11:37 PM | #4 |
I was just asking .... I find that the slag left from the plasma needs more attention prior to welding.
Love your stuff - very innovative if you ask me. Ratty 46 |
06-02-2010, 11:46 PM | #5 |
Hey Nate. How hard would it be to install with the body of my burb on? Can it be done?
68 BB burb build thread Scott's super slam front/rear http://67-72chevytrucks.com/vboard/s...d.php?t=378084 |
06-03-2010, 12:19 AM | #6 |
The top of the notch would be difficult at best... drilling the holes for the mounting bolts would be quite a feat.
06-03-2010, 12:47 AM | #7 |
60-66 Nut
Very nice work as always.
06-03-2010, 01:05 PM | #8 |
Rollin' Old Skool
nice...i'm interested in hearing more about the mild drop kit
06-03-2010, 03:43 PM | #9 |
It's actually in the works. We are finishing up an extreme drop kit for the 60-62 chassis that will be done in July... then we will also do a mild drop version.
06-03-2010, 09:38 PM | #10 |
Hollister, CA.
Ahhh, who cares ?
Once again....very nice work my friend !!!
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" Last edited by ChiefRocka; 06-03-2010 at 09:40 PM. |
06-03-2010, 09:54 PM | #11 |
06-07-2010, 10:26 AM | #12 |
Truck Nut
porterbuilt.....Do you ever see a bolt in c notch for us 73-87 blazer and suburban guys in the future????
Tony Kee Texas Square Bodies Last edited by texassquarebodies; 06-07-2010 at 10:26 AM. |
06-07-2010, 11:35 AM | #13 |
I sure do. We are moving shop this month, and have some square body stuff in line for next month!
06-07-2010, 11:52 AM | #14 |
Very innovative and high quality fabrications.
06-07-2010, 02:51 PM | #15 |
chevy only
Nice work kat, hows the move comming? I will catch up with you this week i am going out to globe to look at a car
CHEVY ONLY... Nothin Else ! |
06-08-2010, 02:11 AM | #16 |
Yet another quality product to impress me!
1964 Chevy Short Fleet: Tornado 1972 Chevy C10: Fast Orange Secondaries Wide Open |
06-09-2010, 01:59 AM | #17 |
The move is coming along great... especially with the 110* weather we have been having.
06-09-2010, 12:15 PM | #18 | |
Extreme weather sux..... hot or cold.
06-09-2010, 12:45 PM | #19 |
No complaints about the type of heat.... but as we all know anything over 100 isn't fun! My wife has family in Kentucky and we visited during fourth of july one year.... the humidity isn't any fun at all.
06-09-2010, 08:12 PM | #20 |
how much drop are you talking about with "'mild" vs "extreme" i assume extreme lays frame with you're reputation.
06-10-2010, 07:52 AM | #21 |
Squarebody guy
06-11-2010, 12:16 AM | #22 |
60-66 Nut
120? I guess that's why they call it Devils Lake?......lake of fire sounds like. Crap around here we're still hoping for the rain to quit and the temps to get over 65 for longer than a couple days at a time.
06-11-2010, 06:23 AM | #23 | |
Squarebody guy
I am over seas right now, stuck in the middle of Baghdad. It will top 135 before summer is over. |
06-12-2010, 12:23 AM | #24 | |
60-66 Nut
Ahhh OK that makes sense now. I know it gets hotter than he!! over there. I just don't understand how anybody can tollerate heat like that. I like the warm weather, but that's just too much. You guys over there have my utmost respect for doing what you do......more so in that unreal heat.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 06-12-2010 at 12:24 AM. |
11-25-2010, 11:32 PM | #25 |
Has anybody used this that has the deluxe panhard bar from ECE? Just wondering if the bracket will clear within the notch.
