Old 06-03-2010, 12:06 AM   #1
oteixeira
Another dumb question, exhaust flanges
OK,
I love this site because I know someone out there probably knows this. I have a perfectly good 2 1/4 inch exhaust system that I want to use with my 05 Silverado 5.3 motor. I am using the stock exhaust manifolds, and while the pipe seems like it will fit, the flanges on the exhaust side are too small. The flanges I have are 3" between each hole (triangle pattern) and a 2 1/4 inch pass through for the pipe. The truck has 4" between the bolts (traingle pattern as well). Does anyone make a flange that will work for me??
Orlando
70 C-20 Custom Camper
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=300251
oteixeira is offline   Reply With Quote
Old 06-03-2010, 07:31 AM   #2
cdowns
cdowns's Avatar
Re: Another dumb question, exhaust flanges
try looking at speedway motors catalogue they have alot of different stuff for fabricating exhaust systems// i'd just take a piece of 1/4" or 3/8"steel plate and make my own
Old 06-03-2010, 11:09 AM   #3
ls1nova71
ls1nova71's Avatar
Hey Orlando, I've been wondering if you were still working on this. As far as flanges go, I don't think anybody makes them. What I've done in the past is to cut some out of 3/8 plate using the original gasket as a pattern. Then take the manifolds to an exhaust shop and find some donut gaskets that fit in the hole, and have the exhaust pipe flared on the end.
ls1nova71 is offline   Reply With Quote
Old 06-03-2010, 11:27 AM   #4
oteixeira
Hey! I just touched the truck for the first time in 9 months. My wife was pregnant with twins and they came 3 months too early, after that 5 months in the hospital to get them OK to come home, and here we all sit.
Orlando
Old 06-03-2010, 08:51 PM   #5
oteixeira
Just to let people know, I ended up getting the flanges from spdexhaust.com. I have a local shop that is going to cut the top of my pipes and weld on a 2 1/2 transition and then flair the ends so I don't have to do anything weird with the flanges. I asked if he could stretch them and he said it would ruin the current flairs on the pipes.
Orlando
