Old 06-03-2010, 12:53 AM   #1
DCOOKE62
How to set up pinion angle with 2 piece drive shaft
I installed a Dropmember and it raisedmy engine so now I need to get my drive line set back up. My question is how do I set my pinion angle with a 2 piece drive shaft and do I need to set this at ride height or what. Thanks for the help.
DCOOKE62 is offline   Reply With Quote
Old 06-03-2010, 01:40 AM   #2
PBFAB.COM
PBFAB.COM's Avatar
Re: How to set up pinion angle with 2 piece drive shaft
You will need to set it up at ride height, and have the engine/trans, carrier bearing, and rear-end mocked up to get the proper angles figured out. Shoot me a call tomorrow, and I will help you get it dialed in! 480-326-6303
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 06-03-2010, 01:43 PM   #3
m6z
m6z's Avatar
Could you or anyone for that matter explain this in a write up? I haven't been able to find this info any where online.
Doug
Looking for a 67-72 short bed driver.....
m6z is offline   Reply With Quote
Old 06-03-2010, 02:10 PM   #4
PBFAB.COM
PBFAB.COM's Avatar
What system are you running?
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 06-03-2010, 02:47 PM   #5
jlaird
jlaird's Avatar
I would be interested in this info too.
jlaird is offline   Reply With Quote
Old 06-03-2010, 04:17 PM   #6
m6z
m6z's Avatar
I picked up a complete SD rolling chassis(deal was to good to pass up). So I'm running their front crossmember and rear wishbone super lift kit. I would think it would be the same as someone running your setup or anyone trying to set up a air ride system at ride height with the 2pc shaft.
Doug
Old 06-07-2010, 12:22 PM   #7
m6z
m6z's Avatar
ttt......anyone?
Doug
Old 06-08-2010, 05:50 PM   #8
67cheby
67cheby
67cheby's Avatar
at ride height the only thing i had to do was raise my carrier bearing 1 1/2 inches thanks for your help PORTERBUILT !!! i am also raising the hoop on my crossmember about 1/2 inch
67cheby is offline   Reply With Quote
Old 06-09-2010, 08:40 AM   #9
m6z
m6z's Avatar
Did you set your motor and trans level? Is the carrier bearing also level (inline with the tail shaft) or at an angle? What is your pinion angle set at ride height?
Doug
Old 06-09-2010, 10:36 AM   #10
67cheby
67cheby
67cheby's Avatar
PORTERBUILT, told me to set the tailshaft at 6 degrees
Old 06-09-2010, 11:59 AM   #11
m6z
m6z's Avatar
Ok. Thanks. What about the rest of it? So your keeping that 6 deg. when you set your carrier bearing? Are you setting your pinion angle at 6 deg up then?
I've always been told to shoot for opposite but equal angles when setting up the pinion angle on a one pc drive shaft. Just trying to make sure this is true with the two pc.
(-6 deg on the tailshaft/+6 deg on the pinion)
Doug
Old 06-09-2010, 12:30 PM   #12
67cheby
67cheby
67cheby's Avatar
thats a great question, i dont know the answer
Old 06-09-2010, 07:32 PM   #13
fixit-p
fixit-p's Avatar
On a two piece drive shaft the #1 u-joint at the transmission output shaft needs a 1* true operating angle (if the tail-shaft is set at 6* drive-line #1 can be set at either 5* or 7*) either way gives the u-joint its 1* true operating angle and gives you some flexibility at the carrier bearing, the rear end pinion angle is set so that its centerline is parallel with drive-line #1.
good info here page 14 covers 2 piece drive lines>>>> http://www2.dana.com/pdf/J3311-1-DSSP.pdf
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 06-10-2010, 08:39 AM   #14
m6z
m6z's Avatar
Thank you. That completly clears it up. Great find.
Doug
Old 06-15-2010, 10:25 AM   #15
dropd80s
dropd80s's Avatar
Anyone who would like to take some of the mystery of setting up drive line angles should take a look at this:
http://www.pirate4x4.com/tech/billav...aft/index.html
Its not a short read but will give you an indepth understanding of how everything should correctly be set up.
Fixit-p thanks for posting that link as it answers another question I had not been able to find a solid answer on.
dropd80s is offline   Reply With Quote
Old 06-16-2010, 11:35 PM   #16
jlaird
jlaird's Avatar
another good read. (the link is page 3 of 4)
http://www.airridetalk.com/articles/...-enigma_3.html
Old 06-17-2010, 04:28 PM   #17
dropd80s
dropd80s's Avatar
Thats one I was looking for, great links everyone. Thanks.
Old 02-10-2011, 10:54 PM   #18
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Thanks for all the linked articles, guys.
66 C20 Service Truck:
Old 09-05-2012, 11:07 PM   #19
ChopperCity256
ChopperCity256's Avatar
the links are not working.. trying to set this up also. i have a Poterbuilt setup but all this is chinese to me... i'm lost!
ChopperCity256 is offline   Reply With Quote
Old 09-06-2012, 12:49 PM   #20
PBFAB.COM
PBFAB.COM's Avatar
To speak to a qualified translator please call 480-297-2621.
It's a lot easier to explain in conversation than in text.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 09-06-2012, 12:51 PM   #21
ChopperCity256
LoL!
