Old 06-03-2010, 08:07 AM   #1
rex01atv
Do different types of lowering spindles center wheel different???
I noticed on my 72 chevy that when i switched from stock spindalls to 3'' beltech spindalls that my wheels seem to be closer to the firewall??? My truck is bagged but it is still quite noticable at ride height??? I have had the truck aligned as well??? Any thought on this??? Different spindalls???
rex01atv is offline   Reply With Quote
Old 06-03-2010, 10:12 AM   #2
panhandler62
Java Mechanic
panhandler62's Avatar
Re: Do different types of lowering spindalls center wheel different???
If the spindles are manufactured corretly they shouldn't so that. You should be able to compare the stock spindles to the drop spindles to see if there is an offset between the ball joint attachment points and the axle.
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 06-03-2010, 08:56 PM   #3
rex01atv
Re: Do different types of lowering spindles center wheel different???
Yea, that makes sense. Too bad I already got rid of the original spindalls! Anybody have this problem???
Old 06-05-2010, 05:24 PM   #4
LONGHAIR
It's going to happen at least a little bit because of the caster. As the "axle" part of the spindle moves upward, it move back slightly at the same time, and that is just on the solid forging. As the suspension travels because of the air-bags, it will be more pronounced.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 06-05-2010, 07:47 PM   #5
KQQL IT
At the body shop.
KQQL IT's Avatar
And the more caster you have in the alingnment. The more noticeable it looks
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 06-06-2010, 07:50 AM   #6
panhandler62
Java Mechanic
If no change is made except for the spindles shouldn't the caster at ride height be the same?
Keith
Old 06-06-2010, 08:09 AM   #7
Ghostwhite
Squarebody guy
Ghostwhite's Avatar
Well, I think I overstepped my knowledge and have myself questioning what I posted. I will let the experts tackle this and I may learn something
Ghostwhite is offline   Reply With Quote
Old 06-06-2010, 08:48 AM   #8
panhandler62
Java Mechanic
I was going to object, but I'll buy that in theory but, in practice --- oh forget it... I was trying to find the specifications for the stock geomotry and got tired of gettinguseless links on Google.
I think it is the lower stance, via the bags, that is responsible for the deflection, not the spindle (not in some noticble way) but I can't really make a case for it without the service manual since it appears that no one has put these figures on line anywhere.
It just seems that the castor would have to be fairly severe to move the wheel backwards a "noticble" amount with no change other than the spindle.
Keith
Old 06-06-2010, 09:00 AM   #9
LONGHAIR
I did say slightly....from the spindle itself. Most of the movement toward the rear comes from the suspension travel.
You are right in the thought of the caster not changing....it just that the wheel moves back slightly.
Old 06-06-2010, 03:09 PM   #10
KQQL IT
At the body shop.
KQQL IT's Avatar
I only noticed it on my 73 when we put 6 degrees of caster in it, for stability at the drag strip
Old 06-06-2010, 08:14 PM   #11
rex01atv
How do I adjust the Caster??? Is this something the wheel alignment shop can do??? If so, what should I say to them???
Old 06-08-2010, 09:38 PM   #12
Pssst
Pssst's Avatar
Truck looks awesome.....anymore pics???
Info on Wheel/Tire size???
Pssst is offline   Reply With Quote
Old 06-10-2010, 08:33 AM   #13
rex01atv
Wheels are boyd rallye 18x9 on all four. Soon to be 20's! Thanks for the reply and comments!
Old 06-10-2010, 09:03 AM   #14
SCOTI
SCOTI's Avatar
Yes, an alignment shop would be able to adjust the caster during an alignment. You can verify where it's currently @ but there might be limitations for how much they can set-up w/your truck vs. what you are 'visually' hoping for.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-15-2010, 10:01 AM   #15
dropd80s
dropd80s's Avatar
yeah dont throw your alignment out the window to try and center your wheels in the wheel wells. Its just the way those trucks are S10s are the same way which is why some people scoot the cab back when doing a body drop to recenter the wheels up front.
dropd80s is offline   Reply With Quote
