Old 06-03-2010, 11:54 AM   #1
creep
Registered Loser
creep's Avatar
Brake Line Size?
I am converting to 4 wheel disc brakes and have a CPP brake booster/master cylinder kit. Does anyone know what size brake line I should run from the prop valve to the rear "T" fitting? I tried caling CPP but I was on hold for like 15 minutes and I don't have the patience for that.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 06-03-2010, 09:03 PM   #2
protrash64
Resistance is Futile
protrash64's Avatar
Re: Brake Line Size?
I am not a brake or hydraulics expert, but the factory set-ups generally have a 1/4'' line to the prop valve and then 3/16's back. I have done all my brakes with 3/16's line.
It's an unscientific survey at best....I'm not sure if disc's require something different.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
