Active Member
![]() Join Date: Oct 2006
Raising bed
For those of you who lifted your beds instead of cutting them to fit a bridge do you have any pictures? And how did you secure them to the bedsides and frame?
67cheby
![]() Join Date: Sep 2008
Re: Raising bed
check out the first few pages of my build thread
Active Member
Re: Raising bed
I am kind of confused looking at the pictures did you just cut the existing flange off and move it up 4 inches? How did you rework the wheel well?
67cheby
Re: Raising bed
cut 4 1/2 inches out of the complete side and raised it up and welded it back together
Re: Raising bed
I did the same thing, but took 6 1/2 inches out. Here's some during and after pics that might help you out.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
Active Member
Re: Raising bed
That makes since seeing the pictures now! Did you do the end panel the same way?
Re: Raising bed
I haven't actually done it yet, but yes, it will be done the same way.
Active Member
Re: Raising bed
If you could take some photos while you do that one too it would be awesome!
Re: Raising bed
Sure, but that one will just be taking a 6 1/2" slice out of the middle and welding the top and bottom back together. It probably won't be for a couple of weeks though, I'm in the middle of swapping the drivetrain from one frame to the other.
Active Member
Re: Raising bed
Sounds good it will be atleast a month or so before I get to even tackle that project. Thanks again for the help!
One day...
Re: Raising bed
Anyone do any step sides?
Truck and auto performance nut
Re: Raising bed
Mine is a step and I just pulled the bed mounting bolts out of the floor, got some big washers and put one one on 4 of the bolts, got 4 straps and put the 4 bolts through the eye of the 4 separate straps, then inserted the bolts and straps to the center 4 holes (of 8) in the bed (2 each side) and a nut on the bottom side of each to hold it. Then just gather the 4 straps and attach to your engine hoist via the hook and lift.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
#13 |
One day...
Re: Raising bed
I need to raise it this much.. i have the idea what i want to do but was just wanting to see another stepper done.
#14 |
Re: Raising bed
On a step, I would just raise the angle iron up and reweld it to the sides. For the front, you could just section the front bed wall, just like I am going to do to my fleet bed. I think it would be much easier on a step-side.
#15 |
One day...
Re: Raising bed
Yeah when i get back on the truck im going to order new bed sides and then ill go from there.
#16 |
Re: Raising bed
LOL! I was a little off track.
#17 |
Active Member
Re: Raising bed
smbrouss70 where do you buy those clamps you are using?
#18 |
Re: Raising bed
Harbor Freight has them the cheapest. They are not listed online, but they have them in the store. Eastwood and a few other places have them also, but they are more expensive. I'll get a pic of the un-opened pack I have when I get home from work, so you know what you are looking for.
#19 | |
Active Member
Re: Raising bed
#20 |
Re: Raising bed
I raised the whole rear section of the frame up, as seen in the pic. So my floor is sitting on the frame the way it normally would, except for the forward-most mount. I still haven't decided what I'm going to do for that mount. I did cut around the wheelwell opening so that I would still be able to bolt the tub in like factory. How much are you going to be raising the floor?
#21 |
Active Member
Re: Raising bed
Enough to clear an 8" notch so I don't know how much that would be I have to get under there and measure, I would think no more then 4-4 1/2 inches. i don't want to cut the frame so I will probaly use square tubing spacers to mount the bed to.
#22 |
Re: Raising bed
Here are the clamps that you asked about.
#23 |
Active Member
Re: Raising bed
sweet thanks man!
#24 |
Nothing to see here.....
![]() Join Date: Jun 2007
Re: Raising bed
here's my writeup on a stepside bed floor lift. I will have to modify it a bit this winter when I weld up a deeper rear notch, but it works great and can carry fairly heavy payloads.
http://67-72chevytrucks.com/vboard/s...d.php?t=409466
Doug ![]() ![]() The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
