06-03-2010, 07:30 PM | #1 |
I need a 4x4 swb frame
I need a 4x4 swb truck frame. Let me know what you have. It can be just ta stripped frame with no running gear. Will consider a lwb frame to chop down. Let me know if you have one or know where one is.
Thank you for your time.
1970 Datsun 240Z 1972 K5 Blazer Highlander 1972 Chevelle 1959 Apache 3100 SWB Fleetside 2006 VTX 1800f Build thread: http://67-72chevytrucks.com/vboard/s...ght=highlander |
06-03-2010, 09:12 PM | #2 |
Re: I need a 4x4 swb frame
I have one that is repaired.It was 68 swb 4x4 that got hit in the front.I cut under the cab and replaced front half with 71 blazer. Has reinforcement plate and power steering box with sb cradle no springs or front axle has dana 60 rear axle hd stock springs ,not sure on gear but I think 410. I would take $400 for it.I am going to Talledaga in oct if you don't find one close before then and could deliver that far.
06-05-2010, 12:58 PM | #3 |
Thank you Junkie, I will keep yours on the possibles list. But if I can I would like to find one closer.
Does anyone else know of one? In a field somewhere etc.?
06-05-2010, 02:03 PM | #4 |
Check with La. member "Victoryauto". He's in Natchitoches and I think he still has one.
Wynne 70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s. Build thread 53 Chevy shortbed 69 Camaro Click here to subscribe Chevy GMC International Truck Club Louisiana Charter Member http://www.louisianaclassictruckclub.com |
06-05-2010, 02:55 PM | #5 |
How about a blazer frame?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
06-07-2010, 08:31 PM | #6 |
Bump ------
06-08-2010, 11:39 AM | #7 |
trucks72
I have got a rolling blazer frame with all the susp. under it. Has a 350 in it, manuel trans, and transfer case in it. $600 would but it.
06-08-2010, 11:17 PM | #8 |
The blazer frame and the truck frame are completely different. Thank you for the offer though.
06-09-2010, 07:57 AM | #9 |
trucks72
All you have to do is cut the rear off the frame a little and put the bed mounts on. We did a truck a couple of years ago this way.
06-09-2010, 01:24 PM | #10 |
But the wheel base (center to center of axle) is longer on a truck than the blazer. So If I were to try and mount the bed, even with re-arranging the mounts, the wheel will be too far foreward. I would have to cut the frame and add like 10 inches or something (can't remember exactly) to push the rear frame arch and spring mounts back.
06-10-2010, 12:12 AM | #11 |
trucks72
You are going to cut a long wheel base to a short if you find one. You could make the blazer one longer with a little more work. I just thought it might help you out. I get some guys here from Brookhaven Ms. Is that close to you?
06-10-2010, 01:29 AM | #12 |
I'm almost on the texas border and down by the gulf in La.
06-10-2010, 01:32 AM | #13 |
I know someone somewhere around here has one of these frames just sitting there rusting away never to be used again. I just hope they run across this thread LOL.
11-09-2010, 07:11 PM | #14 |
Still looking for a lwb or swb 4x4 frame. Let me know what ya got!!
11-10-2010, 10:05 AM | #15 |
bump..... Long wheel base or short wheel base, just let me know what you have I can use either one.....
11-10-2010, 12:14 PM | #16 |
Billsbowtie should still have a 68 1/2 4x4 frame longbed..but its a long roadtrip to rosehill va... (sw va)
It was a calif truck..nice rustfree frame |
11-10-2010, 03:36 PM | #17 |
That is a really long way up there. I will send him a message anyways just to see what he has.
Anyone else have or heve seen anything closer?
11-10-2010, 03:53 PM | #18 |
Under Construction
Ill see how much rust my spare frame has on it....
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
11-10-2010, 04:36 PM | #19 |
That would be awesome!! DFW is definitely within striking distance.
11-12-2010, 11:37 AM | #20 |
To the top again...
11-12-2010, 03:12 PM | #21 |
ttt for you pm sent
03-03-2011, 10:31 AM | #22 |
Back looking again, previous deal fell through.
03-04-2011, 04:32 AM | #23 |
I have a 3/4 4x4 LWB frame for sale ..check the 67-72 trucks for sale ,,It was a tow truck I took down to the frame for my next builder project...
WTB 1972 CHEVY 3/4 4X4 1971 chevy c30 4x4 NAPCO (project) 1972 chevy 3/4 4x4 350/350 4spd, tach, tow hooks,radio delete,heat delete,hubcaps,lockers 1972 chevy 3/4 4x4 383/350 dads original farm truck tilt,tach,tow hooks,hubcaps,radio delete,heat delete 2006 chevy LBZ crew cab duramax,4 inch,beadlocks 2015 chevy tahoe Z71 my fifth one,love em 2016 chevy 2500HD Z71 LTZ duramax midnite 2018 chevy suburban Z71 midnite |
03-05-2011, 06:29 PM | #24 |
Thank you for the referral, but I need to find something closer to me. Someone's gotta have one around here somewhere.
03-05-2011, 06:38 PM | #25 |
You run the inventory on the PAP in your area?
