Old 06-03-2010, 09:37 PM   #1
blazin
steering column and steering wheels
im in the market for a new steering column and wheel. does anyone know of a good place to look? pictures? how your aftermarket column fit?? direct fit?
blazin is offline   Reply With Quote
Old 06-04-2010, 07:09 PM   #2
blazin
Re: steering column and steering wheels
wow not one reply. come on guys someone has to have something
Old 06-04-2010, 07:29 PM   #3
c10seconds
c10seconds's Avatar
Heres what I went with. Its a Flaming River polished stainless column with a budnik steering wheel. From what I remember, it all went in really easy. Im happy with it
c10seconds is offline   Reply With Quote
Old 06-05-2010, 12:41 AM   #4
bjinx
bjinx's Avatar
I used a '68-'72 van column and a early '90s wheel. Had to cut off the top bell of the steering shaft and use a u-joint to connect the two and move the neutral saftey switch up the column a little bit. Can not remember what I had to do to make the horn work with that wheel but it was pretty simple. The truck and van columns are the same accept the van column shaft coming out the bottom is about 3 inches longer.
bjinx is offline   Reply With Quote
Old 06-05-2010, 12:47 AM   #5
blazin
thanx guys.. anymore??
