Old 06-03-2010, 11:31 PM   #1
78GMC SIERRA CLASSIC
Starter sticking
Sometimes when I go to start my 78 gmc the starter won't stop even if the trucks running the starter will still be going??? Any suggestions on what I should do I think the ignition might go a little too far which is causing it?
78GMC SIERRA CLASSIC is offline   Reply With Quote
Old 06-04-2010, 01:00 AM   #2
James McClure
One shot, one kill.
Re: Starter sticking
78, the problem is the starter solinoid sticking. Can be caused by low battery voltage resulting in a high amp draw welding the switch disc to the B+ term and the M terminal inside the sol. Also a weak return spring on the starter drive clutch fork or rusty splines on the armature. If the elec system is up to snuff, get a rebuilt from NAPA. They are cheap and come with a 2 year warentee.
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose.
James McClure is offline   Reply With Quote
Old 06-06-2010, 03:13 PM   #3
wedgemon
wedgemon's Avatar
The pinion drive gear can, also, over-rum the ring gear, causing it to hang-up behind it and hold the solenoid on. Wires get hot and melt, fire starts, etc. I speak from experience.
- Dave
2003 Silverado K1500 Z71 - Arrival Blue
1973 K5 Cheyenne Blazer 350/TH350/NP203
Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift.
RETIRED: 1980 Scottsdale 4x4
Founding Member:
"TILT WHEEL BELLY." Club
wedgemon is offline   Reply With Quote
Old 06-06-2010, 05:28 PM   #4
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
while both of the above replies are right on what you can do before you replace the starter is to get under there and give it a good rap with a hammer once or twice, and see if that clears it up. I had one like that and there was some piece of junk in there that was holding it up on the solenoid or something and it worked fine after a good whack.
that also works if the solenoid is older and hangs up , although in any event it usually means the solenoid is on its way out and will be needing replacement soon enough
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
