Fender Mounting
Hey, gang,
Is there anything that goes between the fender and the inner fender on that lip where they mate up and bolt together? Not at the firewall, but the length of the fender front to rear. I got a full cab rubber kit, and some of the items were bagged but not marked,(shame on you, parts packer person) so I have to match them up with what I remove. But I didn't have fenders when I got the truck, so I was hoping someone could enlighten me. Thanks,
'66 C20 converted to C10, 454/TH400 '66 C10 saved from crusher ![]() |
Re: Fender Mounting
not on mine.
1961 Apache short step. |
#3 | |
Re: Fender Mounting
Also, there is an infill piece at the top of the fender, where it bridges from the front of the firewall to the fresh air cavity, that has a piece of rubber stapled to it. I have also noticed, during disassembly, seam sealer where the front fender nose meets the grille support, but none along the top, horizontal edge of the front fender, where it attaches to the inner fender. I hope this information is helpful. Have a great weekend. |
Re: Fender Mounting
Thanks Tony. I didn't know about the seam sealer, but that makes sense. I have the pieces for the back of the fender, just needed to know about that long seam befor I went together with it.
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
Re: Fender Mounting
This might help as well. 1960-66 Exploded views.
http://67-72chevytrucks.com/vboard/s...d.php?t=405550
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 Last edited by aerotruk63; 06-05-2010 at 01:25 PM. |
Re: Fender Mounting
Good stuff Aero.
Re: Fender Mounting
Yea, that's some good stuff there. Clears up a couple others things too. Like I think I'm missing some parts. Guess I better dig around in the shelves and boxes.
Thanks for the info, guys. ![]()
Re: Fender Mounting
Re: Fender Mounting
Thanks, I most certainly will....Besides, I'm about due for a road trip, anyway.
Re: Fender Mounting
I replaced the inner and outer fenders on my '64 Fenderside last year and there was a some black sealer or antisqueak material between the inner and outer fenders that ran along the entire length of the joint where these two parts bolt together.
Re: Fender Mounting
You can just make out the selaer in this image
Re: Fender Mounting
High Note Horn on your rad support Andice.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
#13 |
Re: Fender Mounting
Aero: The horns on this truck were not a matched pair. One works one doesn't. Can you tell me anything about what I should have if going back to original?
#14 |
Re: Fender Mounting
Based on the images posted earlier there was only one horn on the radiator support for '63 models. Was the same true for '64? Does GMC differ from Chevy? My wiring harness has two plugs
#15 |
Re: Fender Mounting
Thanks, Andice....I figure once I get everything fitted I will put some seam sealer in there and then bolt it all up.
#16 |
Re: Fender Mounting
I have pulled numerous '60-'66 Chevy/GMC trucks apart and never saw any material between the inner & outer fender, however, it make a lot of sense to put some there, since it is metal-to-metal.
