Old 06-04-2010, 07:49 AM   #1
PNW72K5
PNW72K5's Avatar
Bigger Fuel Tank!
Anyone know where or how to get a bigger fuel tank/cell in to the stock location on the 72 K5's??? I know the 73's and newer offered a 31gal but can't find the measurements for it? Any suggestions or ideas would be GREAT! Thanx!
PNW72K5 is offline   Reply With Quote
Old 06-04-2010, 09:46 AM   #2
Burt4x4
Burt4x4's Avatar
Re: Bigger Fuel Tank!
I bought a 37gal tank from NorthWestMetalProducts in Oregon.
Wasn't cheep and it's big. I mounted mine higher than their factory mount and built a stout skid plate for it.
http://www.nwmp.com/
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 06-04-2010, 10:32 AM   #3
pumpkin
pumpkin's Avatar
I built one for my Wheeling Blazer 36 gallons.
pumpkin is offline   Reply With Quote
Old 06-04-2010, 12:53 PM   #4
Critter
Future TOTM Winner
Critter's Avatar
I have the 31 gallon 73+ tank and love it. It is roughly 25 inches wide by 27 inches front to back by 11 inches top to bottom. You have to do a few small modifications to the cross member to get the straps to go on but I don't think its a big deal. My tank was in my blazer when I got it so I don't have experience making the swap, but it does fit in there real nicely. If you get one out of a salvage yard try to get the straps with it.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 06-04-2010, 05:14 PM   #5
bigeasycigars
bigeasycigars's Avatar
I have a leaky gas tank. It's the stock tank. Looking for some help with what I should go with as a replacement. Who's got the best tank and any upgrades I should do when installing the new tank? I'm okay with a 21 gal tank BTW. Hope to hear back! E
'71 K/5 CST Work in progress...In Sicily, women are more dangerous than shotguns.
bigeasycigars is offline   Reply With Quote
Old 06-04-2010, 07:15 PM   #6
72gmcshorty
72gmcshorty's Avatar
At the junkyard i saw a chevy 3500 (1994 i think). It had a plastic tank that looked like it might fit...might want to look into that...
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 06-05-2010, 12:11 AM   #7
old man jimmy
In about 1973 you could get a 42 gal tank made of plate steele (no skidplate required) Has 4 tubes welded vertically thrugh the tank, and hangs on 4 1/2 bolts through the floor. Hangs a little low, and has been drug across more rocks than I care to count with no damage. But have no idea where you might find one today. They also made tanks that went where the side panels are, and another that layed on the floor behind the rear seat with a rubber mat on it, like a raised floor. You would think some of them would have survived somewhere. good luck on your search.
old man jimmy is offline   Reply With Quote
Old 06-05-2010, 03:47 AM   #8
PNW72K5
PNW72K5's Avatar
Burt4x4 ? when you say you mounted it higher than the factory mounted what exactly did you mean, was it hard to do etc..? I would assume u did this for ground clearence
Like the tank and the skid plates a good idea just curious about any other info you had reguarding this. Are u using a electric fuel pump/mechanical, fuel injection/ carb any vacum issues?
Thanks for any information!
Old 06-06-2010, 07:32 PM   #9
Burt4x4
Burt4x4's Avatar
If you look at the pic you can see the two straps going under the tank. NWMP has welded "tabs" that hit the bottom of the frame. I cut these tabs off and welded new tabs lower down and shortened the straps to pull it up. I have a 3" body lift so I rased it about 2.5".
BTW ~ welding on the tank voids the warrenty..oh well it's made of steel and gonna last forever..longer than me hehehe
I am running an external fuel pump mounted on the frame near the tank. The tank has 3 vent tubes that hook up to all the factory vent lines. I omited one vent and used it as a return line connection for my Edelbrock EFI.
