06-04-2010, 01:52 PM | #1 |
67 4x4 vin # question
i'm looking at a truck on ebay and i'm curious as to whether it's a true 4x4 or if it's a 67 truck on a later model frame.
i called the tag office and the lady told me that 4x4s had a K in the vin #. can anybody decode it for me? thanks CS1475102222 |
06-04-2010, 02:01 PM | #2 |
What?
Re: 67 4x4 vin # question
Check out this: http://67-72chevytrucks.com/Chevyear.html
From what I can see off the bat is this: C = 4x2 S = Six cyl 1 = 1/2 ton 4 = PU 7 = 1967 I may be wrong, but check out that link above. The lady at the tag office is correct. C = 4x2 K = 4x4 Though on the newer models, GM combined the two suffix's. "CK series" Typically on the older truck VIN's (67/68), the last six digits are your serial number. Check on the frame next to the steering gear, and you should see those same 6 digits stamped in the frame. Others will chime in and correct me, and or give more advice on your Q.
Chris 1968 K20 Suburban 1972 K10 LWB PU Last edited by vectorit; 06-04-2010 at 02:05 PM. |
06-04-2010, 03:25 PM | #3 |
My 67' K10 Short bed has a K instead of a C, that is on the title, VIN plate, old registration, and the SPIS...hth
Erik 1967 K10 SWB Big Window - Bone Stock 1955 JEEP CJ5 13K orig miles (Resto waiting patiently in the garage) |
