White wall terror
How low can I go
I want to drop my 71 long bed as low as I can go with just coils and I dont want to notch the frame or get drop spindles, but I want to be able to get an aligment and I dont want the frame to smack the axle. So what do you guys think. Thanks... Mark
Big Red - Now its a SWB!
Re: How low can I go
I think you can get away with a 3/5 drop, but you would need a new panhard bar and possibly need a C-notch.
68 3/4 ton ![]() ![]() 41 3/4 ton ![]() 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's Last edited by Jacfourteen; 06-04-2010 at 05:53 PM. |
4/6 all day long no notch needed, you will have to get an adjustable panhard bar...
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
I always heard that 5" or more in back and you need a notch, yours never hits the frame? Did you have to get rid of the bumpstop?
68 3/4 ton ![]() ![]() 41 3/4 ton ![]() 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
White wall terror
Yo Big Al, is that what your rig is running on? If so whats the manufacture on the springs? I need details please. Thanks... Mark
Mine sits about like his (Not sure on exact drop) But it hits frame if i have anything in the back or if i hit a really big bump..
White wall terror
so whats your set up T/C
hy coils in front like 4" in the back colis to same size or some blocks and chenge track bar
cucharitas customs |
#9 | |
Mark, I went with the kit from ECE "Early classics" 4/6....
#10 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
No notch needed. The 4/6 or lower will require drop spindles up front.
Not sure it was done before i got the truck... I will be going lower though in the far future for now i am just going to re do the front cause i think all they did was heat the springs and i want it to ride a little better.. C Notch and bags wil come some day..
![]() Join Date: Jan 2008
I would do at least drop spindles in the front so you can keep some front end geometry in it, and still have some travel left in it. I just did the drop spindles from Early Classic, and they were an easy bolt in,with no problems. Very quality pieces! Good luck
#13 |
White wall terror
Thanks for the replys. I never had this much trouble trying to figure out what parts to order before...Mark
