Old 06-04-2010, 06:36 PM   #1
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Leaf to Coil swap veterans...I need your experience
I am swapping a '72 SWB C10's front and rear suspension, steering, crossmembers, and brakes on my '68 SWB GMC frame. The frame are definitely different, as the leaf frame has small reliefs in the frame to reinforce it on each side of the leaf spring hangers. I left the rivets in the holes and ground it smooth before painting, so from the outside it looks like nothing was there.
I've also noticed that the coil spring frame has some reinforcing plates at the crossmember the shocks mount to. I plan on cutting these out to use on the GMC frame. I also plan to box the frame in front of and behind the trailing arm crossmember.
I have noticed several differences in the leaf frame vs coil frame. The leaf frame is also an early one being a '68 and the coil frame is a late model being a '72. Does anyone thats done one or more of these swaps...have any special information to help me have a successful swap? I worry about everything being strong enough for my 500+hp motor.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 06-24-2010, 01:45 PM   #2
68GMCCustom
Re: Leaf to Coil swap veterans...I need your experience
wow....its like this post fell off into a black hole or something.
Kurt -
Old 06-24-2010, 07:57 PM   #3
raycow
Sorry, I read your subject line backwards. Major brain spazz here. Please disregard my previous post.
Ray
raycow is offline   Reply With Quote
Old 06-24-2010, 09:21 PM   #4
Dingfodgy
Lemme show you something!!
Dingfodgy's Avatar
Unless there is something heinously wrong with the '72 frame- why not just swap sheet metal? Leave the '72 frame as is and make it all purty if you like and box it where you want/need. Once that is done pull the bed, cab and front clip off your '68 and mount it to the newly freshened up frame. Slap in your motor and trans and head on out to the track for some serious radial destruction!
I haven't done this yet (it's on my "to-do" list) but it seems the coil frames have a little kick-out where the springs mount that the leaf trucks don't have. I've seen guys get some fabbed bag/coil mounts and weld them in, which is what I'll probably do. You'll also need to come up with a way to mount a panhard bar, being as the leafers didn't have one. There are kits out there, but like most things...they ain't free!
'67 CST-10 LWB ("Crusty") SOLD
'67 GMC SWB ("Murdock")
2000 K1500 Suburban ("Betty")
'95 BMW 325i ("Joy")
Dingfodgy is offline   Reply With Quote
Old 06-24-2010, 10:19 PM   #5
68GMCCustom
the springs mount at the top to the bottom of the crossmember...the kickout is a plate is a piece of the crossmember that flattens out. I didn't get the panhard mount off the old frame in time (its gone) but understand guys sell them here and there. There are also race products.
the '72 had a cross weld about 12" back from the front left frame end. Like a replacement piece was welded on. my '68 was accicent free.
Kurt -
