GM factory mistake, 350 Vet motor in my 72.
I just bought a 72 GMC Jimmy from an impound lot. After chatting with the original owner. He tells me the truck had lots of power. So when he looked at the front pad serial numbers he couldnt find them after he talked with the dealer. It turns out to be a factory mistake. GM installed a 350 vet motor. Per GM. I have not varified this yet.
Has anyone ever heard of that before?? does this make this a rare truck or an odd ball. Im thinking odd ball. |
Re: GM factory mistake, 350 Vet motor in my 72.
Carb is a Rochester "4MV" Quadra-Jet 4-barrel carburetor. the motor is painted orange.
At the moment im at work, so I dont now what the numbers are. Did the 72 Jimmy's come with 4bbls? |
Future TOTM Winner
Yes we have "heard" of it lots of times, but so far they have all been inaccurate or an engine that was put in by a previous owner etc, but never actually installed by GM. Not trying to burst your bubble, but a whole mess of people on here joke about the "rare corvette option" blazer/jimmy/truck. Just warning you.
![]() On a 350, yes, the 4bbl Q-Jet was very common.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com Last edited by Critter; 06-04-2010 at 08:29 PM. |
#4 | |
I'm a poor spectator
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig ![]() 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! ![]() 1979 Ford F150 4x4 SWB Built Ford Tough!!! ![]() 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
ok these are the numbers ive gotten.
RT head. 3973487X date K 3 1. LT head. 3973487x date k 4 1. Manifold 6263751 Rochester Q jet 17054927 Front pad. V11 I 6 TDG the manifold gives it away. Its a 200hp 350, I can reach the block number. I could use some help with the engine number on the front pad. thanks |
TILT COLUMN GURU
![]() Join Date: Dec 2006
Maybe it's one of those rare Corvette optioned trucks.
kevs_classics64 64 Impala SS Conv 72 Blazer 2wd 75 Jimmy 2wd 63 Belair wagon 02 Silverado ext cab. DD RIP EL JAY |
Pretty sure mine was a corvette 350 too. Crossed the intake number with a corvette and they were both marked 18436572.
![]() btw, welcome aboard!
71 Blazer / GMPP ZZ383 / MPFI / 700R4 / 4-Wheel Disk / Ground-up frame off almost completed resto-mod Last edited by 71RestoRod; 06-05-2010 at 08:10 AM. |
2WD Jimmy
![]() Join Date: Mar 2005
Small block chev is a small block chev. If its in a corvett, its a corvett engine, if its in a truck, its a truck small block. Most vetted just came with regular old small blocks, maybee a bit better cam, its not till you get into things like an LT1. 2.02 heads, SOLID lifter cams, forged cranks, stronger rods and such. Having a corvette 350 means nothing. I have a motorhome sbc 400 in my blazer that will wax a vette 350. Get over the Corvette option. Gm did on ocasion put hotter than called for 350's in vehicles, by mistake, at change overs, or when thay ran out of what was called for. I have a buddy that worked at a GM dealer back when our trucks were new, and he found a few of these. He tells me that the owners of these vehicles, would come in complaining that the engine didn't idle as smooth as his neighbors. So under warranty the would change out the Corvette camshaft for the smaller cam.
as it turns out these motors were in fact put into 72 corvette's. But the rated HP was not much around 200. If you wanted more the LT-1 was the option. So im sure a ton of these motors are floating around.
this guys vet has the same heads, manifold and carb as my Jimmy. So its a plan jane motor. http://www.c3registry.org/index.php?...=4453&uid=1669 Engine: Original 350/200 hp. Vin number is stamped on pad and "VO215CDH". Casting 3970010. Heads: Original Casting # 3973487. Transmission: Original Muncie M-20 4-speed. The VIN number is stamped on the transmission; Maincase Casting 3925661; Sidecover Casting 3952648; Extension Housing Casting 3978764. Rear End: Original Axle Casting # 3899143 Carburetor: Rochester Q-Jet 17054927--This is not the carburetor the car left the factory with. It is a direct GM Service Replacement. Intake Manifold: 6263751-Original |
On your front pad, the Engine Suffix is that of a truck:
TDG 1972 350 conv,cab 175 4 K-10 & 20 TDG 1972 350 M/t 175 4 K-10 & 20 And it is a Flint Plant Motor (V), and I believe the numbers were 1116, which would be November 16th Info: http://www.nastyz28.com/sbchevy/sblock.php#ecode
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3 Last edited by JimmyFloyd; 06-07-2010 at 10:00 AM. |
