Will it work?
I recently bought a power booster with master cylinder for a '78 chevy C-10 but the power booster isn't the one with the four bolts (it has the sub frame instead). I think the style power booster I need would be from an 80ish (82 for sure) S-10. So the question I have is this: would the 82 S-10 power booster mate up with the 78 C-10 master cylinder?
#2 | |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Will it work?
Yes the '78 master will bolt up to the S10 booster, just make sure the short pushrod is that pushes on the master is in the front of the booster. Do you have one of my booster brackets?
Re: Will it work?
Yes I do and Thank You! The bracket looks awesome inside the truck.
