Old 06-04-2010, 10:41 PM   #1
Alex Hayley
vacuum pump recommendation needed
I am looking for a hand-held vacuum pump and see many out there but have no experience with any of them. Can anyone recommend a hand-held vacuum pump?
Alex Hayley is offline   Reply With Quote
Old 06-04-2010, 10:49 PM   #2
mstrav1973
mstrav1973's Avatar
Re: vacuum pump recommendation needed
what are you using it for? how many cfm do you need
Matt
72 chevy k-10, swb, auto, 35's, rally's, posi, 4" lift, 2.5" old style 40 series flows with headers and crossover pipe and some other stuff!!
mstrav1973 is offline   Reply With Quote
Old 06-04-2010, 10:55 PM   #3
Alex Hayley
Good question. My immediate needs are to bleed brakes and test a brake booster. I don't know how many cfm's would be needed.
Old 06-04-2010, 11:02 PM   #4
hayhauler71
hayhauler71's Avatar
http://www.mityvac.com/pages/products_hvp.asp
I have had the silverline for 15+ years in the automotive industry and is also rebuild able but if you want cheep harbor freight has them.
hayhauler71 is offline   Reply With Quote
Old 06-04-2010, 11:07 PM   #5
RichardJ
Hand Held.
You may not want to do what I have always done. I buy cheap plastic ones and always end up dropping them or stepping on them. The good part about that is I have extra plastic reservoirs. Always bleed brakes with two inline reservoirs or make up an extra large reservoir to keep the brake fluid out of the pump. The fluid will screw up a $20 pump just as easily as a $70 pump. The small single reservoir they give you is not enough by itself.
RichardJ is offline   Reply With Quote
Old 06-05-2010, 12:06 AM   #6
dwcsr
Hollister Road Co.
dwcsr's Avatar
Just remember that when using a hand vac for brakes that you don't try to pull down
more than 10 inches. You start sucking air past the wheel cylinder rubbers if you draw to much vacuum.
dwcsr is offline   Reply With Quote
