Old 06-04-2010, 11:37 PM   #1
-dylan-(OO==|==OO)
I dont drive fast,, I fly low!
-dylan-(OO==|==OO)'s Avatar
lowering ?s
im wanting to lower my 72 but dont have the money for a decent set of bags... and i was wondering how low u can get ur truck without bags.. and wat parts do i need to get it as low as possible??
____________
/_______\
(OO==||==OO)
67 GMC CUSTOM,72 GMC...65 chevelle...65 fastback mustang...75 VEGA...90 lx mustang...90 supercoupe...90 jeep wrangler...04 mach 1 mustang...06 toyota tacoma...08 nissan altima
-dylan-(OO==|==OO) is offline   Reply With Quote
Old 06-05-2010, 12:46 AM   #2
SCOTI
SCOTI's Avatar
Re: lowering ?s
5/7 drops are easily achieved while still being able to drive the truck. How to get there depends on the the truck.
The front drop is basically front spindles & drop coils. The rear could be a flip-kit, shackles & c-notches (leaf suspension); or drop springs, lowering blocks, & c-notches (coil suspension).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-21-2011, 12:16 PM   #3
papsoldblue72
papsoldblue72's Avatar
Re: lowering ?s
ok need a little help ..... I want to lower the rear of my truck it has leaf springs and i see that you can purchase a flip kit .... well i am too cheap to do that .... and i really don't want to hack the frame up... can i just take the spring apart and use like one or two of them to get my ride a little lower i mean i really don't want to be on the ground .... just a little lower like 1 or 2 inches would be great .... if anyone has pictures that would be a great help also..... thanks
papsoldblue72 is offline   Reply With Quote
Old 09-04-2011, 10:04 PM   #4
iceship
Re: lowering ?s
It is less work to just flip it.... playing with those spring and that center pin is no joke....
iceship is offline   Reply With Quote
Old 09-04-2011, 11:25 PM   #5
YBNORML
YBNORML's Avatar
Re: lowering ?s
Sure, you can remove a leaf or two. But you will get what you pay for. Both your load capacity and ride will suffer. I removed a leaf from the rear of my s-10 and it became quite bouncy and couldn't handle any kind of load. Not even a set of tires. So, to answer your question. Yes, it can be done. But, at what cost.
Just my .2cents.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 09-05-2011, 09:58 AM   #6
OJ1988
Just a car guy
OJ1988's Avatar
Re: lowering ?s
Flip kits are about the cheapest way do go, you don't have to notch on most. I fliped an 86 without a notch and it was fine.
1955 belair Blown Pro Street cruiser
1971 Camaro Pro Touring
1973 Vega Drag Car
1970 C20 tow rig
OJ1988 is offline   Reply With Quote
Old 09-05-2011, 10:48 AM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: lowering ?s
Originally Posted by YBNORML View Post
Sure, you can remove a leaf or two. But you will get what you pay for. Both your load capacity and ride will suffer. I removed a leaf from the rear of my s-10 and it became quite bouncy and couldn't handle any kind of load....
I agree with most of this statement, but it does need some clarification. You can remove the thick overload leaf for a 3/4-1" drop depending on the thickness of the leaf. That alone won't diminish your load capacity under "most" circumstances. If you pull another leaf out of the pack, your load capacity does start to diminish some.
Using your S-10 as an example is not a good comparison. They have fewer springs in the pack, and a much lighter load capacity to start with.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-06-2011, 10:39 AM   #8
YBNORML
YBNORML's Avatar
Re: lowering ?s
Regardless of what specific vehicle you use as an example, the results are the same.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 09-06-2011, 11:31 AM   #9
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: lowering ?s
Thats just not true. I have lowered several trucks by removing springs from the rear leaf pack. The end result depends on what you started with. If you have a HD spring pack with 7+ leaves and an overload, removing some of the leaves will soften the ride, but will not render it incapable of hauling a moderate load. Fact, not internet fiction.
Articles-
"Refining Sierra"
Old 09-06-2011, 11:47 AM   #10
SIXTY9CST
Re: lowering ?s
Where can i find 1.5 in lowering blocks for a 69 cst with a coil spring rear end?
thanks
SIXTY9CST is offline   Reply With Quote
Old 09-06-2011, 12:16 PM   #11
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: lowering ?s
thanks
Contact board member/ board vendor way2lo2.
He sells lowering blocks.
http://67-72chevytrucks.com/vboard/s...d.php?t=454824
Keith
Convert to disc brakes.
