Old 06-05-2010, 01:08 PM   #1
my69camaro1
Young One
Quick Question - What oil weight stock 1981 454
Bought a bone stock 81 gmc with a 454 a month ago and I'm not sure what weight oil i should put in it.
69 R/S Camaro
79 K5
86 M1008
11 P71 Vic
12 Ram 3500
18 Ram 2500
my69camaro1 is offline   Reply With Quote
Old 06-05-2010, 01:14 PM   #2
Matt Man
Matt Man's Avatar
Re: Quick Question - What oil weight stock 1981 454
mine says 10-30 but mine is a replacement motor from ac delco i would imagine that is it the same.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 06-05-2010, 01:23 PM   #3
my69camaro1
Young One
K thanks.. I used wiki and it was saying 15w40 and that seemed off.
69 R/S Camaro
79 K5
86 M1008
11 P71 Vic
12 Ram 3500
18 Ram 2500
Old 06-05-2010, 01:46 PM   #4
GmtGmt
Conversion Truck Addicted
GmtGmt's Avatar
all older cars and trucks i give them a good 10W-40 from Mobile or Valvoline
Thomas
Tonight mine pulled a few cars out of snowbanks, and is sitting in my driveway, icicles on the grille, wheels just white cakes of snow, buried up to the lug nuts in powder, straps and chains wrapped around the bumpers, the outline of the wipers clear in 4 inches of snow on the windshield... A tired warrior of the 1980s in a world of low profile tires, front wheel drive, and plastic bumpers, where people stay in their houses until snowplows move the offending substance from their paths, too helpless to travel without AAA and chains and salt, clearing their windows with longhandled brushes while gently stepping around in the snow trying to stay nice and dry.
GmtGmt is offline   Reply With Quote
Old 06-05-2010, 02:52 PM   #5
78 Chevyrado
i use 10w40. the reason some people say to use the 15w40 is its a diesel oil and it still has (or had) some of the additives gasoline engine oil is missing. (govt Removed what we need) I don't know if diesel oil still has the zddp or whatever in it still. it helps flat tappet camshafts not wear as much.
78 Chevyrado is offline   Reply With Quote
Old 06-05-2010, 05:18 PM   #6
country29
you are correct, it still has the zddp, here in eastern AR I run 15w-40 rotella T until it gets cold, then run napa 10w30. Also for those that dont know, napa oil comes out of the same plant valvoline does, ashland petroleum in ashland ky, if you want to save a few bucks next oil change. just my .02
country29 is offline   Reply With Quote
