Old 06-05-2010, 01:40 PM   #1
67Chinook
Rear axle swap
I've searched the archives and nothing.
My friend has a 63 short wide bed and is looking at a 72 axle.
I say it's different but he thinks it will fit.
67Chinook is offline   Reply With Quote
Old 06-05-2010, 05:01 PM   #2
raycow
Re: Rear axle swap
The 72 axle will sort of fit. The main differences are that it is about 1-1/2" wider than the 63 and the panhard bracket is made as part of the center casting. If it were mine, I would cut the panhard bracket off the 63 and weld it onto the 72 housing. The extra width normally isn't a problem unless you just plain don't like the look.
Ray
raycow is offline   Reply With Quote
Old 06-06-2010, 12:19 AM   #3
Captainfab
60-66 Nut
Re: Rear axle swap
The '71 & '72 rear differential is a common upgrade when looking to convert to 5 lugs. Yes they are 1 1/2" wider than the '63-'early '70 differentials. If you have the means to do the welding, or have someone do it for you, switching the panhard bar mount from the '63 diff to the '72 would be a good idea. If you don't have the means to do the welding, you can use the shorter '65 and later panhard bar, but you will need to put a slight bend in it to get it to line up with the bracket on the frame.
Old 06-06-2010, 01:56 PM   #4
rain_man
rain_man's Avatar
Re: Rear axle swap
what year is this
thanks
61 step/long bed SBW(SOLD)
NEED A NEW PROJECT
rain_man is offline   Reply With Quote
Old 06-06-2010, 11:56 PM   #5
Captainfab
60-66 Nut
Re: Rear axle swap
That looks like a '65-'72 12 bolt under a '60-'62 truck.
Originally Posted by rain_man View Post
what year is this
thanks
Old 06-07-2010, 12:52 AM   #6
apachedaddy
apachedaddy's Avatar
Re: Rear axle swap
Looks just like the one in my 66 but that one looks like it is missing the trailing arm perches to bolt it down.
66 short wide fleet sbw = Gave to my best friend
66 short wide fleet bbw
apachedaddy is offline   Reply With Quote
Old 06-07-2010, 11:19 AM   #7
Chevy Fleetside
Chevy Fleetside's Avatar
Re: Rear axle swap
I have a 72 rear axle in my 65.. It was a straight swap.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 06-07-2010, 11:23 AM   #8
rain_man
rain_man's Avatar
Re: Rear axle swap
thanks capt
NEED A NEW PROJECT
Old 06-07-2010, 12:16 PM   #9
LILRED66
LILRED66's Avatar
Re: Rear axle swap
With a modified Panhard bar.
LILRED66 is offline   Reply With Quote
Old 06-07-2010, 12:39 PM   #10
rain_man
rain_man's Avatar
Re: Rear axle swap
so if i want to swap to 5 lug in the rear i should do what?
NEED A NEW PROJECT
Old 06-07-2010, 12:46 PM   #11
SIR
SIR
SIR's Avatar
Re: Rear axle swap
don't forget to trim that extra 1-1/2" out of the inner lip of the rear wheel well cut it! don't just bend it up out of the way...I've seen that one and it doesn't work...
66long low fleet http://community.webshots.com/user/LVNR66
SIR is offline   Reply With Quote
Old 06-07-2010, 10:40 PM   #12
Chevy Fleetside
Re: Rear axle swap
I did a straight swap. Used the panard bar from the 65 and didn't have to trim any metal off of the wheel wells. Maybe back spacing has something to do with it. I know I ordered my wheels to fit the rear end. I think you can see the clearance in these pictures. I can't remember the back spacing but it might be 3 1/2 but I can't say for sure. The rims are 7" wide.
I am also guessing the modified panard bar is for the 63 year model. Mine is a 65.
Old 06-08-2010, 12:44 AM   #13
Captainfab
60-66 Nut
Re: Rear axle swap
I would look for a '71-'87 rear end. Even if you find a '71-'72 rear end, the trailing arm mounts won't line up, as the '60-'62's are farther apart. Once you find a rear end, you'll have to cut off the factory mounts, and weld on the ones for the trailing arms in the correct location. Then I would remove the panhard bar mount from your original rear end and weld it to the new one. I believe that CPP and ECE sell a rear end swap kit with the necessary parts, if you are unable to reuse your original parts. They also sell just the trailing arm mounts if that's all you need.
Old 06-09-2010, 12:28 PM   #14
67Chinook
Smile Re: Rear axle swap
Thanks guys.
Turns out his truck is a 60, so it must be different than a 63.
Old 06-09-2010, 06:52 PM   #15
raycow
Re: Rear axle swap
I have a 60, and am still running the stock rear for the reasons Captainfab mentioned. The easiest swap for these trucks is a 60-62 GMC if you can find one. This is a bolt-in with no welding needed. It's a Dana with much better highway gearing then the Chevy rear and you can still get parts for it.
I couldn't find a GMC close to home (still looking though) so went with an overdrive tranny instead. If your friend's rear is still good and he just doesnt like the gearing, I would recommend the same to him.
Ray
Old 06-09-2010, 11:52 PM   #16
Captainfab
60-66 Nut
Re: Rear axle swap
Yes, '63 was the first year for the 12 bolt, the trailing arms were closer together, the shocks were mounted differently. And of course the completely different frame and front suspension.
Originally Posted by 67Chinook View Post
Thanks guys.
Old 06-10-2010, 11:58 AM   #17
67Chinook
Re: Rear axle swap
Great info guys. I'll tell him about the
GMC swap, but he wants to go 5 lug because it already is 5 lug in front.
Old 09-12-2010, 12:46 PM   #18
mike67
Re: Rear axle swap
This seems like a good thread to post this question. I'm going with the ECE super track bar kit and don't need the panhard bar mount on my rear differential. Can somebody give me a couple of tips on how to remove the panhard bar mounting stud? I'm really not sure how to go about this. Any help would be great.
mike67 is offline   Reply With Quote
Old 09-12-2010, 11:18 PM   #19
apachedaddy
Re: Rear axle swap
BFH is how i got mine out. It took a couple good wacks. Just hit it from the front side (by where the drive shafts go's) it will pop out the back side. It's a tappered fit and prob been in there since built LOL.
Old 09-12-2010, 11:52 PM   #20
SCOTI
SCOTI's Avatar
Re: Rear axle swap
Cut it off flush w/the housing w/a cut-off wheel.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-13-2010, 12:25 AM   #21
Captainfab
60-66 Nut
Re: Rear axle swap
In addition to the above, if you want to remove the whole stud, try heating the casting right there with a oxy/acetylene torch. You will want to do it as quickly as possible, and not so much that you get the carrier bearings too hot. Once it is hot smack it a couple times with a BFH and it should pop right out.
Old 09-13-2010, 03:50 AM   #22
raycow
Re: Rear axle swap
I vote for cutting off the stud. If you pound on it there is a very real risk of breaking the casting.
Ray
