06-05-2010, 03:21 PM | #1 |
60 big window apache
i went and looked at this one today. he said it runs good but the battery is dead and it wouldn't crank.
$3000 obo. it's a 283 with a 3-speed manual, no power steering or brakes. the rockers have been replaced at some point but the cab corners need some attention--not too bad though. it needs a back glass, passenger door glass, and the windshield is foggy around the edges. bumpers and grill are decent (not bent but pitting a little) and bed wood is rotten. it also needs a passenger door-rusted through on bottom. do the beds on these fit right up against the cabs? it only has about 1/2 inch between the two. i thought about offering him $1500 cash for it. i found the right hood for $500--ouch! |
06-05-2010, 03:43 PM | #2 |
Check The Champ, Demonstrator
Re: 60 big window apache
Lot's of goodies on the truck. No pictures inside the cab or engine compartment?
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
06-05-2010, 03:53 PM | #3 |
here are a couple.
i should've taken some myself. it's nothing special under the hood or inside the cab. the floor pan has a few rusty spots on the pass side but the drivers side seems ok. the moulding looks pretty good on the drivers side but the pass side has some of it dented up and has sheet-metal screws in it. Last edited by cris well; 06-05-2010 at 03:56 PM. |
06-05-2010, 04:04 PM | #4 |
Sheet metal screws through the molding, costly to repair & replace. Nice truck.
06-05-2010, 06:06 PM | #5 |
call me crazy but has anyone ever put one of these on a 90 model frame?
i have one that is still TBI w/700r4 and already lowered with vette rallys and new tires. this 60 would look good dropped with all the newer comforts of the 90. |
06-06-2010, 12:28 AM | #6 |
60-66 Nut
This has been mentioned before......Forget about swapping the frames it isn't worth the effort if it is even possible. The '88 and newer frames are much wider and a different profile than the earlier frames. Just keep the '60 frame and upgrade the suspension (there's a thread specifically on that) and install the TBI 350 and 700R4 into the truck.
I have installed a '62 body onto a '74 frame, and I don't even recommend that unless you're building a lifted 4x4.
06-06-2010, 08:41 AM | #7 |
I'd see if it runs first. Windshield is easily 500 dollars, plus seal, plus labor.
idk, 1500 sounds fair enough if it runs. |
06-06-2010, 09:25 AM | #8 |
I would offer 1200 and If he says no wait a week and then offer 1500.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
06-06-2010, 09:43 AM | #9 |
Safelites web site says they will do the windshield for under $300 installed. I checked when I got my '63 two months ago.
1961 Apache short step. |
06-06-2010, 10:38 AM | #10 |
06-06-2010, 11:50 AM | #11 |
Not sure about the wrap around's for the 60-63 but my 66 was 140 installed. I had the new seal allready, it was 38 bucks i think, so yes safelight is cheap and they did a very good job on mine.
66 short wide fleet sbw = Gave to my best friend 66 short wide fleet bbw |
