How to connect the original and mechanical temperature gauges.
I just bought a mechanical water temperature gauge and would like to continue to use the stock gauge and the machanical gauge. The only place I saw for the sensor was where the stock one is located by the exhaust manifold. Is there another location that will work for the mechanical temp. gauge too or do I have to disconnect the stock gauge?
Thanks! Aaron
![]() Buford - 1971 3/4 ton, Custom Camper, 350 Th, 350 SBC. |
Gone to greener pastures
![]() Join Date: May 2007
Re: How to connect the original and mechanical temperature gauges.
There should be a twin locations diagonally across the engine from each other, in the heads.
That would be between #1 & #3, and #6 & #8 spark plugs on a SB; & above #2 & #6 spark plugs on a BB; IIRC.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck Last edited by El Jay; 06-06-2010 at 07:24 PM. |
Don't you have any ports in the intake manifold?
Ray |
"THE GREEN GOBLIN"
x2 ^ intake manifold I've heard this is the best place for the temp.
![]() "THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi ![]() Drive it like you stole it! ![]() Petey-pablo@sbcglobal.net |
Cool, I'll look on the intake. Does anyone know where on the intake it's located? This is my first chevy, I know on my fords they use to have a spot on the thermostate housing.
Thanks, Aaron
Start at the thermostat housing and follow the water passage out to each head. Most OE manifolds will have a temp gauge port on the driver side and a heater connection on the passenger side. If you aren't running a heater you can use the heater port for an aftermarket gauge. The heater port is normally too small for an OE sender, but you can open it up with a 1/2" NPT tap if necessary.
Some aftermarket manifolds will also have tapped holes over the rear water ports in the heads. These aren't the best location for a gauge, but you can move your heater line there to free up the front hole and the heater will still work just fine. Ray Last edited by raycow; 06-06-2010 at 02:33 AM. |
I noticed that the water pump has two plugs that are screwed into the top and the passenger side. Can I move my heater hose to the water pump and then use the intake for the temp. sensor? Or can i run my temp sensor in the water pump? Thanks for all the help, this is a great forum!
Aaron
Junior Member
I am a little confused, but that is nothing usual for me at times, lol.
The stock location for the temperature sending units are on the engine heads, not the exhaust manifold. Should be one on each head. Some water necks are available with a place for a temperature sending unit. Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
I ended up installing it where the original sending unit was located. I will install the stock one in the water pump when I get buy the adaptor. I did find the other water jacket on the head between 6 & 8 cyclinders, but it wasn't breaking with the breaker bar so I decided that it wasn't worth breaking.
Thanks All!
If you put a temperature sender in the water pump, you'll be reading the temperature of the water going to the engine, not the water in, or coming from the engine.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
