67-72 Air suspension/driveline issues- Need some help
Here's the skinny,
I have a 67 SWB that has a complete mild air suspension from ART. I have almost the entire Porter catalog except for the dropmember. I am having some issues with driveshaft interference when I air up. The rear bags almost have to be completely aired down and the front has to almost as low so that the driveshaft does not contact the center crossmember. I am looking for some advice on how to trouble shoot what could be the problem. The shaft is 3.5" diameter. I had this sized to meet the horsepower the engine. Could this be a pinion angle issue? Can you shim up the transmission mount? Any help would be greatly appreciated. Thanks Also I can post pics later |
VA72C10
![]() Join Date: Mar 2008
Re: 67-72 Air suspension/driveline issues- Need some help
One piece or two piece driveshaft? do you have his trailing arm crossmember with carrier bearing? Pics will probably help...
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
One piece driveshaft.
Here are some pics |
VA72C10
Have you talked with Nathan? I assume you could raise up the tranny mount pending how that affects your engine angle....can't tell that from the pics.
Squarebody guy
I'm pretty sure you would need a two piece for that specific trailing arm member, but wait for nate to answer.
Matt-
PM sent. I have the perfect solution. ![]()
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
#8 | |
Thanks |
Tot Roddin'
Curious... what was the solution?
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
I will be sending him a different variation of the crossmember.
Awesome Service!
#13 |
#14 |
Hey there Heymoe,
I was having simular clearance issues as you desrcribed and was wondering if the new style cross member is going to hit the floor of the cab??? As for Nate he is top notch with outstanding customer service.
1967 GMC shorty Parts Pile: NoLimit, Accu Air, Kore 3, Matts Classic Bowtie, March Performance, Lokar, ScottsHot Rods, Vintage Air, American Auto Wire, Circle D, Accu Air, Borla, Budnik, Ididit, One Piece Windows, Doug Thorley, Pypes, AutoLoc, Porterbuilt, CPP, Dynamat, Dakota Digital, Fesler 1968 Chevy c10 shorty Stepper (Patina LS project) 1967 gmc custom Long Box (Farm Truck Project) |
#15 |
yes i believe you have to cut a strip out to fit
#16 |
There are NO clearance issues with the upper bar on the TAXM and the cab. There are some pics of Project Old Aux (that was body-dropped) where the floor was modded. Factory cab mounts will yield no clearance issues.
#17 | |
Thanks again Nate for all the help, Are you done yet? ![]() |
