What would cause this ?
I started to pull apart my 307 with 55.000 miles on it. I know that the truck has been sitting for 13 years so i just planed on putting new gaskets in it but then i found trouble.
I pulled of the crank and looked at the cam and it was pitted. What would cause that ?? I also notice on some of the water ports of the head there was some weird stuff in them. I would almost say it looks like solder melted and hardened. Not sure what thats about. |
Re: What would cause this ?
Pitting or rust on any internal part would probably be caused by condensation inside the engine. Condensation will occur during the warm/cold cycles of our seasons.... especially up by you. Think of it this way: the engine is out in the cold all winter long. The first couple of warm (above freezing) days the engine warms up to ambient temperatures, but the oil remains cold, because it's so thick, thus causing the condensation inside your engine. Same thing happens to your gas tank. I noticed a considerable amount of sweat on the gas tank of my '49 back in March. It had just started to warm up outside, but the gas was still cold. Beyond this explanation, I would have no idea what caused the pitting.
Not sure about the stuff in the water jackets without some pics. Last edited by 1949gmc; 06-05-2010 at 11:41 PM. |
Could be ?
The blowby gases get absorbed into the oil; the moisture combines with these impurities to make an acid, which eventually eats away the cam and bearing surfaces. This means that you should never store an engine that has old oil in the crankcase.
72 Fleet (died) 78 Step (sold) 55 Step named Fred (sold) 00 F150 68 Step (named El Scorcho by PO) Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932 |
GEARHEAD
The weird stuff in the water jacket might be from a stop leak product. The corrosion is likely from what the others have posted. Since the engine will be pulled apart for gaskets any way, just do a rebuild. As long as it doesn't need a ton of machine work the cost is not that bad doing it yourself or with some help from an experienced friend.
I did a shortblock rebuild for about $400 last year, including honing, mag test the block for cracks, dipping the block and polishing the crank journals.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff |
On the path to financial ruin!
![]() Join Date: Jan 2009
Guys have all made various points in which I agree with 100%. Therefore, no need for me to say the same thing. But, I will add this...you now need to rebuild the whole engine and not just swap gaskets.
'72 Chevelle SS--4.0 Whipple LS7, T56 Magnum, 20X9/20X13 HRE 791R, 6-piston Baer brakes, IRS '68 SWB C10--LS3, TKO-600, 22x10/22x12 HRE 948R, C5 suspension, shockwaves, custom frame Ooh Wee's Makeover...http://67-72chevytrucks.com/vboard/s...d.php?t=376280 |
with the sealer crap in the jacket would scare me// would do nothing less than a hot tank and magnaflux of block and heads to see what you have to start with
at that price i'd in all honesty scrap it and look for a rebuildable 350 core b4 getting that deep into the 307
#8 | |
![]() Join Date: Aug 2001
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
I want to keep it a numbers matching truck, so thats why im sticking with the 307. And its not a hot rod so i wont need alot of horses. I had some one check out what that weird stuff was and they said it was metal that didn't get cleaned out from when the heads were cast.
