Lube a spedometer cable?
Good afternoon everyone. I recently installed a new spedometer cable and I am wondering should I put some kind of lubrication in the cable housing? I have avoided any highway cruising 70+ MPH because I don't want to ruin it.
If yes, what kind of lube and how to do it? Thank you for your time! ![]() Keith |
Re: Lube a spedometer cable?
autoparts store has speedometor cable lube// it's dry graphite based and actually polishes the cable and inside the housing for resistance free spinning
20' Daredevil (Ret)
![]() Join Date: May 2003
^ x2... I have used lightweight lithium grease without problems, but graphite is the way to go.
If you have problems getting the graphite into the sheath, add some rubbing alcohol and create a good mixture. Use a squirt bottle to get the liquid into the cable, the alcohol will act as a carrier and evaporate shortly after installation leaving behind the graphite as a lubricant.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle Last edited by 71 super; 06-06-2010 at 06:46 PM. |
I always pull the cable from the back of the odometer. Then slid the center part out of the sheath. Lube. Re-install.
Never use that white lithium lube in the north country where it gets cold. That stuff freezes.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
