Old 06-06-2010, 03:31 PM   #1
54Caddy
GM Addicted
54Caddy's Avatar
Cool Square bodies bagged with stock a-arms
i really want to bag my truck. Id be happy to get a dropmember from PB built but cant afford that was thinking of using an upper plate and a bucket to put in my stock a-arms how low will it actually go? and also ive never really dealt with bags before so what all would i need to make it work? Also the rear would i be able to do a flip kit with some leafs removed and use a bag between the frame and axle just to get it to ride height? Any help would be greatly appreciated.
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 06-06-2010, 08:39 PM   #2
baggedk5
baggedk5's Avatar
Re: Square bodies bagged with stock a-arms
Ive got stock a-arms and on 22 inch rimz it and the lower arms are on the ground, saven up money for drop member (almost there)
baggedk5 is offline   Reply With Quote
Old 06-06-2010, 10:58 PM   #3
jmedero
jmedero's Avatar
Holy smokes. That k5 has a bunch of lift.
Ok back to the subject... My 68 burb will put the lca's 1 inch from the ground. It has factory arms up front.
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 06-06-2010, 11:22 PM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
If you go with a 3" dropped spindle, plates and stock arms, you can lay the control arms. You will need to pull the inner fenders, but it will lay hard on the arms. You can't get any lower with out a raised or sectioned crossmember, unless you Z or body drop.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 06-07-2010, 07:14 PM   #5
54Caddy
GM Addicted
54Caddy's Avatar
Bagged k5 what do you have in the rear thing lifts up like a coca-roach ahaha. Also what bags up front. New to this bagging stuff can some one explain the hole set up to me ahaha
..Mac’s Garage..
IG:MacsGarage
Old 06-07-2010, 08:20 PM   #6
DKN
Active Member
The CPP tubular arms are designed for this type of install. The CPP arms will allow the crossmember to hit the ground, NOT the arm. The extra ground clearance can make for a much improved ride.
Danny Nix
CPP
DKN is offline   Reply With Quote
Old 06-08-2010, 02:45 AM   #7
54Caddy
GM Addicted
54Caddy's Avatar
which CPP arms tubulars??
..Mac’s Garage..
IG:MacsGarage
Old 06-08-2010, 10:53 AM   #8
DKN
Active Member
They are listed on this page.
http://www.classicperform.com/NewPro...ubularArms.htm
Danny Nix
CPP
Old 06-08-2010, 05:14 PM   #9
baggedcten
86 C10
baggedcten's Avatar
Danny Nix
CPP
any pictures of them installed?
1986 C10
2001 chevy silverado purchased 8-29-09 sold
2004 silverado purchased 8-27-10 sold
baggedcten is offline   Reply With Quote
Old 06-08-2010, 06:09 PM   #10
54Caddy
GM Addicted
54Caddy's Avatar
Little expensive for my blood right now ahhaha.
..Mac’s Garage..
IG:MacsGarage
Old 06-08-2010, 06:32 PM   #11
edflores
Danny Nix
CPP
Pics or it didnt happen
edflores is offline   Reply With Quote
Old 06-08-2010, 06:37 PM   #12
kev2809
low n' slo
kev2809's Avatar
lol
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 06-09-2010, 04:28 PM   #13
69Rob
69Rob's Avatar
Here is my 86 with factory control arms they do hit when on 22's but the 24's wont let them hit unless i cut out some of the fire wall or low pro tires
2009 dodge hemi custom paint
86 lwb bagged layin frame
73 2 door nova
54 bel air
69Rob is offline   Reply With Quote
Old 06-09-2010, 04:34 PM   #14
lolife99
67-72 parts collector,…
lolife99's Avatar
Really clean longbed!
Keith
Convert to disc brakes.
Old 06-09-2010, 07:04 PM   #15
54Caddy
GM Addicted
54Caddy's Avatar
Whats everybody running in the rear. Would help to know also.
..Mac’s Garage..
IG:MacsGarage
Old 06-09-2010, 07:43 PM   #16
69Rob
69Rob's Avatar
my rear is two link set up ekstinsive here in houston sells its made to lay out on 22's comes with every thing needed
73 2 door nova
54 bel air
Old 06-09-2010, 07:45 PM   #17
69Rob
69Rob's Avatar
Thanx always liked long beds better just a look they have layed out
73 2 door nova
54 bel air
Old 06-09-2010, 10:05 PM   #18
baggedk5
baggedk5's Avatar
hope these pics help u,sorry so dirty havnt had time to wash under truck today,if u need bettr pics ill send some with wheels off
Old 06-09-2010, 11:20 PM   #19
54Caddy
GM Addicted
54Caddy's Avatar
the top of the bag is mounted on an upper plate? and in rear a 4 link or what?
..Mac’s Garage..
IG:MacsGarage
Old 06-09-2010, 11:21 PM   #20
54Caddy
GM Addicted
54Caddy's Avatar
How much there kit run?
..Mac’s Garage..
IG:MacsGarage
Old 06-10-2010, 06:56 PM   #21
69Rob
69Rob's Avatar
https://www.ekstensive.com/store/pro...ca6abf84a884bc
not really sure how to post a link but thats it if it works if not just go to www.ekstensive.com its 650 dollars and comes with every thing needed other then shocks
73 2 door nova
54 bel air
Old 06-11-2010, 01:24 AM   #22
edflores
You didnt have to modify anything? The notch just fit? the pinion angle must change a ton with how short those bars are.
Old 06-11-2010, 10:08 AM   #23
dv8customs
dv8customs's Avatar
I had a kit like that on my '04 and it worked fine (little pricey for a 2 link though). The notch dropped right over the frame like its intended, so you just weld up the outside edges then cut the middle out. Only problem mine had was that the shock tabs on the bars were not at the same angle as the ones on the bridge so I had to do some tweaking to get the shocks bolted up.
dv8customs is offline   Reply With Quote
Old 06-11-2010, 12:00 PM   #24
54Caddy
GM Addicted
54Caddy's Avatar
the kit for the rear sounds good any one have any others that arent way pricey??
..Mac’s Garage..
IG:MacsGarage
Old 06-11-2010, 12:34 PM   #25
dv8customs
dv8customs's Avatar
You can get a triangulated 4 link kit from Suicide Doors pretty cheap. That is what I have on my '86
