Bent Frame?
Can any of you guys tell me if this is normal or is the passenger side frame bent? I have been looking at it and when I bought it the PO had bent in the pass side bumper and fender. I didn't even think to check the frame. Here is a pic of trhe front:
[IMG] The area in concern is right here. It seems as though the curl in the frame might have been factory but it also seems to be bent underneath: [IMG] Not a great pic of the bottom of the frame but.... [IMG] And here is my driver side (not bent) [IMG] Thank
67 C10 Stepside 66 Mustang Coupe 99 Burb 2500 |
Gone to greener pastures
![]() Join Date: May 2007
Re: Bent Frame?
Looks to me that truck took a pretty hard hit on the passenger side.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
Re: Bent Frame?
Whats the best course of action here? I didn't notice any significant pull to the side when I drove it.
67 C10 Stepside 66 Mustang Coupe 99 Burb 2500 Last edited by 67Slider; 06-06-2010 at 04:04 PM. |
Re: Bent Frame?
straight edge off harmonic balancer and measure to end of frame ???
Devil's in the Details
Re: Bent Frame?
That curve on the top rail of the passenger side is normal, but I agree that from the pictures your frame does appear to be moved too far over to the driver's side.
'70 K10 Suburban - TBI 454, 4L80E, NP241C, Dana 60 & 44 - The 10+ Year Project Thread Datsun 240Z, 510 2 door and an old Honda motorcycle |
Re: Bent Frame?
8.5 Pass / 9. Driver from HB. Looks like I'm about .5 inch off
Cruzin
Re: Bent Frame?
i just went out and tooks some pics for ya, didn't realize how much i missed painting the other day
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
Re: Bent Frame?
It is bent up under on the bottom side of the frame. If I stuck a piece of wood in there and hit the wood with a sledge would that bring me back out? Or am I better off taking her to a shop?
Re: Bent Frame?
Thanks for the pics. They do answer a lot of my questions. It is definitely bent/towed in a little too.
![]() Join Date: Aug 2001
Re: Bent Frame?
If you've got a decent frame shop locally it's definately worth the time ,trouble & money. They can put it on a frame rack & fix it right. I think slow & steady with a hydraulic ram instead of hitting it with a bfh is the way to go.
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
![]() Join Date: May 2009
Re: Bent Frame?
Not sure where you took the measurements from but, the passenger frame rail looks to be rolled under and swayed more than 1/2". Measurements on top and below frame rails will probably be different. You would have to tie down at or behind the suspension cross member and pull the right rail over, You might be able to put a hydraulic jack (portapower) between the cross member and the end of the frame rail.
My goal in life is to be as good a person as my dog already thinks I am - Unknown |
Re: Bent Frame?
I would take it to a shop. Also body panels have a better chance of lining up when the frame is correct. May run about $500 or six hundred at around $90 per hr. Many people ignore the frame then complain about the poor fit of body panels.
#13 |
Grandpa in the rustmobile...
Re: Bent Frame?
thats wierd mines the same way, never had trouble aligning it or driving it lol
thats 3 trucks in the same place same size...bend wtf (sorry no pics my trucks not at home its in rust repair prison for while)
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#14 |
Re: Bent Frame?
also all our trucks are 67-or EARLY 68 (me)
#15 |
Re: Bent Frame?
I would say that if it rides fine and the body panels fit fine, leave it, unless you plan to road race this thing or take it above 100 mph. These trucks were never 100% even from side to side.
#16 |
Re: Bent Frame?
Is no one else thinking that its odd they're all bent in the same exact area the same way on the same side lol?
#17 |
Re: Bent Frame?
make it 4 trucks with that bend
#18 |
Re: Bent Frame?
I am not seeing a problem.
The bend upward on the top of the frame rail is normal. If it took a hit that bad, surly there will be a crack in the frame somewhere. Build on, Danny Last edited by Kayotic; 06-18-2010 at 06:54 AM. |
#19 | |
Re: Bent Frame?
#20 |
Re: Bent Frame?
Didn't say had to be cracked, just something to look for if it's in question.
I have had 2 trucks where the upright on the front cross member had been shattered on frames that otherwise looked ok. I have also come across a frame that had a crack inside the bend of the c-channel. 39,000psi tinsel strength steel and age would crack in a high stress situation. Tool Time lol... When was that memorable... |
#21 |
Registered Cruiser
Re: Bent Frame?
I had the frame straightened on mine when I first put it on the road.. It wasn't real bad, but was $250 well spent. (1997) If it's off far enough for you to passively see that it's off, you should do something about it.
I intend to live forever. So far, so good. |
