06-06-2010, 08:02 PM | #1 |
?? electric speedo to cable speedo
I just got my 72 burb roadworthy but the 700r4 has electric speedo connection. Can it be changed to the the cable driven type and what is needed?
http://www.picturetrail.com/jwill41 67 1/2 ton GMC short step side 68 1/2 ton Chevy long fleet side 72 1/2 ton Chevy Suburban 99 1/2 ton Chevy Suburban founder (and only member) of the primer/clearcoat club |
06-06-2010, 08:22 PM | #2 |
Re: ?? electric speedo to cable speedo
I answered in your other thread
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
06-06-2010, 08:26 PM | #3 |
thanks for the fast reply. I sure didnt expect it to cost that much to accomplish. I will have to stay without a speedo if thats my only option.
06-06-2010, 09:34 PM | #4 |
I answered in your other thread too.
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
06-08-2010, 09:58 AM | #5 |
i don't know what the other guys' answers where,but, the on the 700 in my 57, the trans guy swaped to an older tail housing from an early 80's 700. my transmission was out of an 87 iroc.
06-08-2010, 01:02 PM | #6 |
I haven't seen your other thread, so I don't know what is in there. May I correctly assume that the Cable-X and modified tailhousings have already been suggested? IMO, these are both rather high $ fixes. Unless you are dead set on a stock dash appearance, you can install an aftermarket electric speedo for a lot less money.
Ray |
06-08-2010, 07:24 PM | #7 |
06-09-2010, 09:17 PM | #8 |
Thank you. I just now looked at that thread. Have you pulled the electrical connector out of your transmission and looked inside? If you have a gear in there, that fix will work. If you have a "reluctor", which looks like a small turbine vane, your job just got a bit harder. Please take a look at it and let us know what you find.
Ray |
06-09-2010, 10:11 PM | #9 |
I plan on looking at it this weekend and will post what I find.
