Old 06-06-2010, 08:03 PM   #1
Jwill41
Jwill41's Avatar
?? electric speedo to cable speedo
I just got my 72 burb roadworthy but the 700r4 has electric speedo connection. Can it be changed to the the cable driven type and what is needed?
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline   Reply With Quote
Old 06-06-2010, 08:21 PM   #2
Thealien
Thealien's Avatar
Re: ?? electric speedo to cable speedo
Here is 1 solution
Old 06-06-2010, 08:50 PM   #3
low'n slow
Too Dumb To Know Better
low'n slow's Avatar
Yes, you can get another tailhousing. Street and Performance sells them.
low'n slow is offline   Reply With Quote
Old 06-06-2010, 09:21 PM   #4
nightmare
nightmare's Avatar
my new transmission was supposed to use the electrical speedo connection, but I just installed the cable style, which I already had, and it fit just fine. I didn't have any problems with it, just make sure you use a new o-ring seal. I didn't have to change the tailhousing at all.
Of course you will need the cable housing, driven gear, and the o-ring seal. I suggest the aluminum housings, since the plastic ones can break. Here is a thread with the part numbers and other info: 700R4 Info.
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 06-06-2010, 09:48 PM   #5
Jwill41
Jwill41's Avatar
Thanks. Thats more like what I had in mind. Does the electronic version also use the "drive" gear and is it the same for cable version?
Old 06-07-2010, 01:22 PM   #6
nightmare
nightmare's Avatar
Yes, the drive gears are the same.
Mike
67-72 FAQ
Old 06-07-2010, 06:44 PM   #7
Jwill41
Jwill41's Avatar
cool, I just need to find a donar tranny
Old 06-13-2010, 12:14 PM   #8
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
To switch you need to pull the tail housing off, pull off the reluctor wheel (metal wheel) and slide on the plastic speedo wheel, bolt up the tailshaft and toss the cable drive on the outside and the party is done!
I did it on my 67 in about 30 minutes and didn't loose much in the way of ATF.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 06-13-2010, 05:16 PM   #9
Jwill41
Jwill41's Avatar
thanks for the description of the change. I have not tried anything yet as I have been busy on a few other things but hope to get to it soon.
Old 06-16-2010, 12:01 AM   #10
Sublvr72
Sublvr72's Avatar
I'm facing the same problem on my TH400 in my 454/auto swap
Sublvr72 is offline   Reply With Quote
