Old 06-06-2010, 09:17 PM   #1
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
How important is it to weld a brace on inside of cab before..
How important is it to weld some braces on the inside of my cab when i replace floor/rocker parts...
Im replacing just about everything on the floor/rocker areas Ive already got my pass. side door off.
My floor supports are gone (4)
should i weld a brace on the drivers side? Any tips for any of this? Thans
John
1999 Toyota Tacoma 4x4
Old 06-06-2010, 09:40 PM   #2
crushermechanic
crushermechanic's Avatar
Re: How important is it to weld a brace on inside of cab before..
i would definatly brace up everything. better safe than sorry. i braced from floor to roof, door openings, rear of cab to dash and cross the cab.
crushermechanic is offline   Reply With Quote
Old 06-06-2010, 09:53 PM   #3
Number98
Prestige Worldwide
Number98's Avatar
Originally Posted by crushermechanic View Post
i would definatly brace up everything. Better safe than sorry.
x2
Number98 is offline   Reply With Quote
Old 06-06-2010, 10:12 PM   #4
oldblue1968chevy
ok well right now pass. side door/rocker is off..
still weld some braces, i also plan on doing the upper windshield patch
John
Old 06-06-2010, 10:46 PM   #5
LockDoc
The Older Generation
LockDoc's Avatar
The cab should have been braced before you removed anything. Also, when you put the rockers in it just tack weld them in and put the door back on to check the alignment in the front. A lot of people don't do that and end up with the front of the rockers in too far. I hope you marked around the hinges with a felt tip marker before you took them off so you know where to bolt them back up for the correct alignment....
LockDoc
Leon
Old 06-08-2010, 05:07 AM   #6
tim21391
tim21391's Avatar
i didnt brace anything and i came out just fine.. oldblue u seen my thread i did everything but the windshield area
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 06-08-2010, 10:38 AM   #7
oldblue1968chevy
thanks locdoc and tim! I did mark around the hinges im not THAT stupid lol...
ima re read your thread tim thanks!
John
Old 06-08-2010, 11:16 AM   #8
StingRay
StingRay's Avatar
Yes sort of. If the cab was dimensionally correct before then yes and if not then sort of. I've found that when these cabs rot out the rockers, corners and floor that the whole B pillar can spring out of whack. I've only done a couple cabs but have had to lever the B pillars back, adjust the A to B pillar spacing and cross measure the cab to square it up as best I could. If you brace in a way that problems can't be corrected then you might not be doing yourself any favors.
I adjusted my doors, fenders, cowl and hood as perfect as they could be done before starting and then made corrections to the cab where I felt it needed to done as I made the rust repairs. I readjusted all of the panels time and again through the process removing and installing as needed. It takes a boat load of time
Oh and yes I braced the cab but I did it in such a way that I could adjust it if necessary.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
