LMC Cowl Seal garbage
So what is the trick to make this thing not throw my hood out of alignment? This is the one that is shaped like an "L". I belive it is suposed to layover so I taped it over to maybe help it start to form and let my hood lower but am wondering if theres a better option or if I need to trim it or something. So far I would say I am un impressed with the quality of over half the stuff I have recieved from Lmc, very poor quality and fit on a lot of their stuff.
Matt
72 chevy k-10, swb, auto, 35's, rally's, posi, 4" lift, 2.5" old style 40 series flows with headers and crossover pipe and some other stuff!! Last edited by mstrav1973; 06-06-2010 at 09:35 PM. |
Nothing to see here.....
![]() Join Date: Jun 2007
Re: LMC Cowl Seal garbage
every cowl seal I used did the same thing, regardless of maker or vendor. the "new" plastic did not lay over enough. I just took mine out and left it out.
I guess you could try sitting it out in the sun with a few heavy books on it. this may help form the plastic into a tighter bend.
Doug ![]() ![]() The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
Has more rust than truck...
Ok, so where can we get a good cowl seal? Classic parts currently is back ordered on them.....and I don't know if they have a good seal or not.
2WD Jimmy
![]() Join Date: Mar 2005
ttt
Do you have a pic of it installed. I used one from lmc and had no problems.
when installing parts on old classic vehicles it helps if you can outthink the part and make it perform the way it should b the best
thats the big difference between being a parts changer and a technical restoreation specialist
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 06-07-2010 at 10:54 AM. |
Between Trucks...
You might have to adjust your hood hinges.
Beat it to fit, Paint it to match... ![]() |
#8 | |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
I think that Sinister hit the nail on the head. The hood to cowl seal is meant to seal the area between the hood and cowl. If it lays over it just doesn't do an effective job of sealing. After about 3 or 4 months the seals will relax a little and start laying down some, however your original had 40 years of relaxing to lay the way they do..
![]() Quote:
Most times what I have found out when the back of your hood sets up is the hood hinges are worn out, and need replacing. To check your hood hinges you just lift the hood, grab it by the front and move it side to side. Look at the rivets in the hinges and if they are moving around, your hinges are bad. When you set a hood with worn out hinges on a new seal, the seal will hold it up in the back. The reason that the hood may not have done that befor is that it was sitting down on a worn out hood to cowl seal. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
By the way we have 2 sets of Genuine GM Hood Hinges in stock. I am not a fan of the reproductions myself. WES
yep, the several that I had were plastic, just like the gutter conduit.
hummm, might have to start looking to get a correct rubber one from ya, Wes
I just checked my supply of those and I am down to 1..lol It looks like I need to order some of those in..
trucks72
You can get them from GM also. That is what I use on our trucks. Just a little more expensive.
#13 |
Good info... You got the part number? WES
#14 |
trucks72
I am not at the shop now. I wiil post when I get back.
#15 |
The GM ones fold back.....I heard they also repop them with the fold, just need to find the right supplier!
More Info: http://67-72chevytrucks.com/vboard/s...d.php?t=394421 RM
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288 Last edited by Rack Man; 06-07-2010 at 12:37 PM. |
#16 |
Registered Cruiser
I installed a new cowl seal a few weeks ago. It made the hood ride up a little less than an eighth of an inch. I figured a hood adjustment would solve this, but I've waited in order for the seal to relax some before I do so. New door seals are the ones that fit really tight.
I intend to live forever. So far, so good. |
#17 |
Here is a picture of our hood to cowl seal. They lay back like the originals also. WES
#18 |
Well I found the part number and the GM ones have been discontinued. WES
#19 |
My contact at GM told me they are discontinued and none can be found in the original package to confirm it is really a GM part. Part no. 6270848. Apparently, some dealerships carry the reproduction stuff, too.
#20 |
I bought mine from Classic Parts and it lays back like the original and is made of rubber, its pliable enough that it does not interfere with the hood closing. I ordered all my parts from Classic Parts and have been very happy with the quality.
#21 |
My hood hinges are tight and they have a fresh coat of gloss plack powder coat on them.
Matt
72 chevy k-10, swb, auto, 35's, rally's, posi, 4" lift, 2.5" old style 40 series flows with headers and crossover pipe and some other stuff!! Last edited by mstrav1973; 06-07-2010 at 08:59 PM. |
#22 |
trucks72
That is the right part number. I just got 20 in last week. I called today and they can not get any more. I must have got the last ones thay had.
#23 |
mstrav1973, Was that seal bent at a 90 from the package? If not, loosen the screws across the front of the cowl and pull the seal forward. It just takes about a 1/16" to allow the seal to lay down a bit. The vertical part looks to be hard against the cowl. WES
#24 | |
#25 |
